2011 4x4 leveling kit suggestions...?
I have a 2011 F-150 4x4 ecoboost supercrew with a 5.5' bed and am looking to get a good leveling kit for it. I want the truck to actually sit level so i know it has to be a 2" or 2.5" kit. I would also like to get 33" mud terrain tires under it without it rubbing. has anyone already done this to their truck? Suggestions....? Thank you
Daystar ComfortRide 2.5 inch Strut Spacer Leveling Kit is another option. $140 shipped
Belltech makes a lifting strut that will get you 2" of lift. I can do these for $180 shipped. Part # 25002
(to Brute448) shocking as it may be, I would like to try to leave the factory rims on, at least for now. As can be said for many people currently, I am on a budget. That being said my last truck was a '99 F-250 with a "2.5 Ruff Country leveling kit and 35" Mickey Thompson MTZs and I am just not used to sitting this close to the ground. Just need that little bit of extra clearance. Thanks for the info
I'm open for any additional ideas or input if anybody has any.
Is it possible or let me say logical to put a spacer on top of a Rancho QL. I would of course leave the QL set on it's lowest setting. I am assuming the QL on the 1 setting is equivalent to the stock strut length. I want this for the look and better ride/handling characteristics
What offset on the bmf rims ?
Wade
I am running the Bilstein 5100 adjustable ride shocks up front and really like them. Motofab kit is great and runs $74 on Amazon right now. Bilsteins are about $94 a shock and then you need to have a spring compressor to get them on. Most shops will charge $150 - $225 to put the Bilstein struts in for you. I have been told that when you go to the level 3 (2.25" height) on the Bilsteins, the ride get a little stiff compared to stock.
