04 4wd Coilover Front Suspension, installed on 97-03 trucks?
Has anyone tried or looked into putting the coilover front suspension from an 04 F-150 4WD onto a 97-03 F-150 4wd?
Seems like it could be alot of fab-work, but wondering if it could be a lesser expensive 4wd coil over solution compared to Dixon brothers or Rock Krawler for 97-03 trucks.
After owning a 97 and now a 2003, I want to do something cool with my 03, but stupid lift laws in Maine get in the way. (No body lifts on ABS equipped vehicles, No tire sizes larger than 2 in over the factory optional tire size, funky maximum front frame heights)
The CV axles themselves seem to be shorter in 04, with more splines on the outboard end. Without digging in too deep, it seems Control arms, steering spindles, bearings, brakes etc, would all have to be converted, (and to 6 lug wheels/ 6 lug rear axle). I'm guessing the fabwork would primarily be to the control arm mounts, and upper coilover bucket. Not sure on on swaybar/steering linkages.
What's the silver bullet that would make this not possible?
if I was budgeting a plan for this, I'd be considering the wheels to be needed on either side of the equation. I wouldn't run my stock wheels on a Dixon suspension for example.
Also, I'm hoping that there would be some CV durability gain (note to self - research the reality of durability between 03 CV's vs 04 CV's) The Dixon system would provide new CV's, but RockKrawler would not
Looking for coil-over performance, without as much lift as Dixon or Rockkrawler provide, and gain durability in the process
Don't get me wrong - If I won the lottery tomorrow- I'd probably just have Dixon build me a truck , but looking for alternate lift/suspension system that could reasonably handle 35's with lots of down travel.
theres no way to change it without doing what I did. torsion bars to coilover is completely different. you need a shock mount, different arms and possibly a different spindle. you might be able to somehow make it work but why is the question? and then you would have to figure out what shocks to run and how to keep it cheap and it just gets ridiculous. all that time and money would be really just making your head hurt. if there was a way I would say you could maybe use 2wd stuff, remount the a arm tabs and figure out a way to use your 4wd spindle with the 2wd lower arm and then make a cheap upper arm but again thats just something that wouldnt be worth it.
Thanks for the replies. After doing some more review of trucks running the LT suspensions from Dixon and H&M, I'm struggling when looking at the overall cost. I do have good fabricators in my area, and looking at both DBR and H&M, it seems that you pretty much cut off everything and weld up the mounts for the respective setups.
I was trying to figure a way to get more CV durability AND ditching torsion bars, utilizing factory suspension components to cut down cost. After more reading it seems that the 04 CV's don't like more than 2.5 in of lift either, so no gain to use those, even though they are higher splined.
I think the cost of the DBR setup has come down since I looked at it years ago, for my 97 F150. (or maybe it's more affordable / more reasonable sounding to install on an 03)
I guess I'll have to keep saving my pennies.
