Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 05-04-2012, 11:39 PM
2005 Ford F-150
Vehicle: 2005 Ford F-150
Changing shocks on 05 F-150
I have been running the autospring level kit for about 4 years now. I've never had any problems with wear and tear. I'm wanting to change the shocks. Should I upgrade to the Rancho quick lift & RS9000XL shocks? Or do I stay with the RS5000 shocks? Are the struts hard to disassemble and assemble? The RS5000 has separate shocks for the front and rear.
Old 05-09-2012, 08:43 PM
2006 Ford F-150
Vehicle: 2006 Ford F150
I am in the same situation and am considering the same options. Some people are saying the rs9000 quicklift give a little less than 2" of lift. Some are also complaining of a harsh unloading after going over a speed bump. I like the idea of being able to adjust the shocks but I wonder if I would ever spend the time to mess with it. I often carry heavy loads in the bed so being able to stiffen them up would be nice. Looks to be about $150 difference between the two options after rebate.
2006 Ford F150 Supercrew 4x4
Smokestone Lariat, Fully Loaded!
Gryphon Programmer
Flowmaster Dual Exhaust
Old 05-10-2012, 02:50 AM
2005 Ford F-150
I'm like you, be nice to adjust, not sure how much I would though. I'm running 325/60/18 Toyo right now, if the Quicklift doesn't raise to where I'm at now, will they clear?Are you running a level kit now? Your truck looks good.
05 F-150 SuperCab FX4 5.4
18X9 GEAR BLACKJACK WHEELS
325/60/18 TOYO OPEN COUNTRY AT
Rhino Liner & Extang Trifecta Cover
Air Raid Jr. Kit
Flowmaster Single Side Exhaust
Pioneer AVH-P4000
Old 05-10-2012, 09:30 AM
2012 Ford F-150
Ours give 2.5" to 3.0" of lift, totally adjustable on or off the truck come pre assembled. www.f150lifts.com coming soon!
Old 05-10-2012, 09:33 AM
Garage is empty, add now
Vehicle: 2005 Ford F150
I can pretty much guarantee that if you had the ability to adjust your shocks, you would. I have the R9000XLs on my truck and adjustable shocks are just about the best thing about my lift. I stiffen the ride when towing the boat and can soften the ride on long road trips. I do not use the on board compressor however. Although it would be nice, it's not a big deal to turn the dials manually.
The QuickLift supposedly gives less than 2" of lift, but so do the Bilstein 5100's (had those too). If you have some leveling requirements, you can always use the standard length R9000xl and put your spacer on top of that.
I personally love this shock and highly recommend them.
Click the image to open in full size.
Old 05-10-2012, 02:18 PM
2005 Ford F-150
According to Rancho's site, the R9000 are not made for the front.
Air Raid Jr. Kit
Pioneer AVH-P4000
Old 05-10-2012, 02:42 PM
Get the Bilstein 5100 series For front and Back! Here is my setup I just did last month - 2'' leveling spacer, Bilstien 5100 adjusted to 1'' setting for max 3'' in the front, 2.5'' Rear Block, New Ball joints and Tie rod ends! The Only hard part about doing all of this really was Compressing the coil enough to get the new struts on!
Old 05-10-2012, 02:45 PM
Quote:
Hey, did not know that...I checked out their application guide and there's no R9000xl for 0" stock height, 4wd....interesting. I'd place a call to them to be sure, but I guess they only offer the Quicklift strut with 2" setting on up. Good info.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
