05-01-2012, 08:53 PM
camburg upper control arms
i have a 2010 f150 with a zone 6" lift, the lift uses longer struts in the front. no spacers or coilovers. my question is can i use the camburg upper control arms on my lift or will they rub the spring? prob gonna add a daystar 1" spacer while its apart.
05-01-2012, 09:39 PM
Garage is empty, add now
Vehicle: 2008 Ford F150
They should not rub the spring, except maybe under full deflection, do your wheels have the proper offset so that your tires will clear them? If possible can you post a pic of your current setup.
2008 4x4 Lariat 5.4 SCREW, Navigation
2.5" Auto Spring, BOW, K&N Drop In
DH Platinum, Gryphon Programmer, Wagner TQ
295/70/18 Trail Grapplers, Magnaflow SI/SO
05-01-2012, 09:52 PM
not sure about pics. current wheels are 18x9 xd addicts. not sure on offset. run 35x12.50x18 toyo mud terrains with them.
05-01-2012, 10:25 PM
1998 Ford F-150
Vehicle: 1998 Ford F150
You'll definitely need to know the offset to figure out if the arms will work.
05-01-2012, 11:38 PM
The offset should not matter because you are lifted. The point where the uca connects to the spindle is much higher then the wheel or tire. You need to worry about the wheel offset and new uca when you are stock height.
05-02-2012, 10:07 AM
1998 Ford F-150
While that is true if the offset is really positive around where the stock wheel is he can have still rubbing issues off the tire hitting the arm.
05-02-2012, 04:57 PM
ill try and figure out my offset...do know my tires stick out a good inch outside the fenders
05-02-2012, 07:34 PM
2009 Ford F-150
Vehicle: 2009 Ford F-150 FX4
You should be fine, but check your wheel back space. I plan on upgrading to them here soon
I need help...
05-03-2012, 12:13 PM
1998 Ford F-150
Quote:
In that case you should be okay, but still knowing the offset would never hurt.
05-03-2012, 04:49 PM
rims are 4.5 backspacing
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company |
