Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 04-29-2012, 01:38 PM
2004 Chevrolet Cavalier
My Garage
Vehicle: 2007 Ford F-150
100000407687965
Send a message via AIM to DarrenWS6 Send a message via Yahoo to DarrenWS6
Ball Joints & Tie Rods
Well time for round 2. Went through this on my 2004, now my 2007. My front right tire is wearing bad on the outside so I am going to get it checked out this week. To be prepared, I want to get parts ready so that when I find out what it is, I can get the parts replaced with products I provide, and don't get ripped off on the labor like I did with my old truck ( $930 for lower ball joints alone ). I am quite sure it is not the alignment as I had an alignment done by the dealership back in January. I had it done because that is when I started noticing the tire wearing more on the passenger side, but it was not pulling like it does now. Perfect timing for this to come up, was just a day or two away from ordering some exhaust components to finally get that done. . Every time I plan a modification, it seems something else always comes up.
Everyone says Moog makes fantastic suspension parts for OEM replacement, seems the obvious route to take. Any one disagree?
I found on Moog's website they have the lower control arm assemblies with ball joint, and bushings for $280 per side. The best deal I have found online is $169.87 per side from Auto Parts Express. Does anyone know of anyone that charges any less with them in stock?
For some odd reason, Summit Racing has them priced ridiculously high, right about where Moog themselves do. I am going to attempt to make an offer for them to price match Auto Parts Express for my business. If they do not accept, is Auto Parts Express reputable and timely?
RockAuto.com has them for $191.79, I could also try to have them price match Auto Parts Express if Summit fails.
Now for the upper ball joint, I can not find replacement arms for the uppers, but I swore that Moog did make OEM replacements? Or is that for lifted suspension vehicles only?
Will it also be worthwhile to replace the tie rod ends at this time? ( Granted that those are not the issue, if they are, then I will just have to anyways ). I do not want to replace what I do not have to, however if it will involve ripping the entire front end suspension apart I will just get it all done. I don't know if it is possible without accessing the tie rod ends without removing the struts or anything else. I want to buy the Rancho QuikLift setup but at this time I will most likely order a 2" AS spacer kit to have installed since the struts will be out. Someday I will order the Rancho's, I can sell the AS to a friend who has an FX4 in the future so it seems worth while.
Hopefully this resolves quickly and that I only need to replace what needs replaced. At this rate I will need new tires and I am not too well prepared to buy new ones if I need to do all of this suspension parts. Meanwhile I guess I will start looking up tire prices for a new pair of Trail Graps for when this is all done.
2007 Ford F-150 Lariat Supercrew 5.4L 4x4
Exterior: PTM handles/bumpers/mirrors, Harley Davidson grill, PTM Leer 700, 3M 5% tint, Glossy pillars
Interior: Black leather, Audiophile, Weathertechs
Drivetrain: 3" Magnapack SI/DO, PHP Gryphon 93oct, PowerSlot Rotors, Hawk LTS pads, 20" XD Monsters 33x12.5 Toyo M/Ts
Old 04-29-2012, 02:06 PM
Garage is empty, add now
Vehicle: 2004 SCrew
I looked at Rock Auto and found the upper control arms, K80306 for the L/H and K80308 for the R/H. Is that what you were looking for? How come your wanting to change the lower arm assy instead of ust the ball joint? Hope that helped.
Tim
Winter - 2004 Lariat Screw 4x4, Whipple and more
Summer - 2010 Mustang GT with Paxton and suspension
Old 04-29-2012, 02:10 PM
My Garage
100000407687965
Quote:
Tim
I just wanted the upper arms if I needed the upper ball joints changed.
I know that the lower ball joints can be pressed out, but I figured this way it would get new bushings and an already installed ball joint. Is it better recommended I just provide those parts and have the dealership replace the ball joints from the original arms?
Old 04-29-2012, 02:23 PM
Vehicle: 2004 SCrew
Yeah I understand having the upper arms. I have a set in my garage with lower ball joints waiting to put them in some day. As far as the lowers go, I guess its a horse a piece with just ball joints or the whole arm but I would think it would be a little less money to just change the ball joint. The upper arms and lower ball joints is just over 200, then you need the labor. I don't know for sure, maybe ask the shop which is the better choice.
Tim
Old 04-29-2012, 03:17 PM
Vehicle: 2004 ford f150
wow im in the exact same situation kind of. my right front tire has horrible wear on the outside so i replaced upper arms, lower balljoints and tie rod ends. I guess it was the messed up toe that was causing the wear since everything else was in spec.
2004 F150 Fx4
Old 04-29-2012, 06:59 PM
My Garage
100000407687965
Quote:
Dang, sorry to hear that! Tell you what though, I sure hope that that is all that is wrong with mine.
Old 04-29-2012, 08:28 PM
2007 Ford F-150
My Garage
Vehicle: 1994 Ford F-150
Send a message via AIM to lakemarykid
Just curious have you done typical check for bad ball joints? IE: Jack the truck up and check for play in the tire? Grab top and bottom and see if there is play.
-Curtis-
94' F-150
SAS, Cage Radius Arms, 12" Lift, 1.5" .250" DOM Trac bar with 7/8" heims, Tie Rod and Drag Link w/ Chevy 1 ton TREs, 38.5" Boggers, 15x12 Eagle Alloys, 4:88 Yukons, Aussie Locked My SAS Build
07' F-150 Supercrew FX4 Luxury Package - DWV/Gotts Intake, 2.5" HBS, 295/60R20 Nitto Trails, WeatherTech Digital Fits, Gryphon Programmed, Magnaflow Magnapack, 5% tint, Firestone Ride Rites
Old 04-29-2012, 08:40 PM
My Garage
100000407687965
Quote:
-Curtis-
I have not. I thought that was a check for bearing though. I will give it a try after work tomorrow afternoon. I have looked over everything and there are not any ripped CV boots, or ball joint boots and all that. The edge of the bushings look a little weathered on the lower control arms however.
Old 04-29-2012, 08:45 PM
2007 Ford F-150
My Garage
You may be right. I thought grabbing the tire at 9 o'clock and 3 o'clock was for bearings and 12 o'clock and 6 o'clock was ball joints.
-Curtis-
Old 04-29-2012, 08:49 PM
My Garage
100000407687965
-Curtis-
Either way I'll do it all even west coast time style .
Old 04-29-2012, 08:58 PM
-Curtis-
I'm pretty sure
ball joints = up and down
tie rods = left and right
Old 04-29-2012, 09:23 PM
1995 Lincoln Towncar
My Garage
Vehicle: 2000 Ford F150
Send a message via MSN to Gotts2BMe
jack up the truck under the lower control arm. Get a bar under the tire and try to lift it up. If it moves it is lower ball joint. Push and pull the top of the tire (12 oclock). If it moves upper ball joint. Grab the tire in the middle towards the front of the vehicle (either 3 or 9 depending on which tire, driver or passenger side) it will likely be outer tie rod, possibly inner. If you start to get movement at any time look to see where the movement is. upper/lower ball joints, inner/outer tie rod ends, or wheel bearing. If it is the wheel bearing/hub assembly it will move at any position you push and pull the tire.
Honestly don't waste your time replacing the whole lower control arm if it is the lower ball joints. Just an fyi as well the lower ball joints on all 4x4 IFS suspensions will wear out first. Doesn't matter the make.
2006 Ram 5.9L - 2000 F150 5.4L - 1995 town Car 5.4L - 1995 EGT 1.8L - 1991 ELX 1.8L
Nothing stock
Old 04-30-2012, 09:19 PM
My Garage
100000407687965
I did all of this today and nothing budged. The wheel rotated when turned, that was about it. So I looked very carefully and the front right looks like it is veryu slightly turned out to turn while the drivers side does not look that way. I measured from front of tire to back of tire, there is a 1/4" to 1/2" difference. Problem discovered, it has to be the toe alignment. Earlier today I scheduled an appt. with the dealership for Wednesday to look everything over and repair the cause.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
