The Do's and Don'ts of Lifts
Thanks for the input I'll go back and edit that along with add the info for the 04-08. See what I was thinking was with the blocks there and a large amount of weight it would possibly cause axle wrap faster than it would on a truck with no blocks. Also I was thinking that since majority of people forget to regear it would cause even more stress on the transmission with larger tires and the same amount of weight they might be used to normally hauling.
i believe the towing part is wrong. as long as the tires that you bought have the same rating you can tow the same amount. blocks do nothing to decrease the leaf springs weight handling ability.
aftermarket leaf springs however, are usually softer and decrease your towing capacity.
nice write up dude. One thing im curious about is wheel spacers. ive a lot of bad stuff about em, but it seems like as long as you put them on perfect, and retorque them frequently they're alright? the reason im askin is cause the doetsch spindles i got are going to push my front wheels out about an inch and a half. so id like to get 1.5 inch back wheel spacers
And since your considering doestch spindles I'd recommend either springtech or canuck motorsports over them. They're all the same brand and it'll save you a little bit of cash.
http://www.4wheelparts.com/Wheels/Al...76&t_pl=103343
Haha oh yea I forgot about that. And I don't really mind mine with it being wider in the front, frankly I like the widened stance of the front. But it's all really personal opinion. I'd say put the spindles on and if you don't like the way it looks then go from there. And back to the spacer's they're kinda hit or miss so people have constant problems with them, other's run them forever without having a single problem.
jerhelo, does your friend happen to have a spindle lift? im getting one and they push the tires out 1.5 inches and im just curious if the 1.5 inch spacers perfectly match that? also how do the bolt pattern measurements work/ 5 x 4.5 and 5 x 5. i realize the first number is the number of wheel lugs currently on the factory rotor. is the second number the distance between 2 of the lugs across from eachother?
