Pop/Clunk in front end
Old 06-20-2011, 06:15 PM
RandomHero34's Avatar
I have a 2004 stx 2wd with 48,500 miles on it and a 6" PC lift that i have only had on the truck for maybe a couple thousand miles. My truck was making clunking noises when going over any bump so i changed out the sway bar end links. that fixed the problem of the clunking over all bumps. except when i am backing out of a drive way and the wheel is turned, when the tire goes off the curb onto the street it makes this very loud clunk/pop. i cannot figure out what is making this noise. the sound only started about a month ago. any ideas? i am going to re torque everything down this weekend again.
Old 06-22-2011, 01:24 PM
anyone?
Old 06-22-2011, 01:44 PM
mdhawkin's Avatar
Perhaps a failing ball joint on one of your control arms. Another thing you may want to do is go back under and re-torque all your suspension components that were added/modified by adding the lift. Have heard of cases like this where components have come lose.
On last thing, not sure what tires you have, but any chance your tires when cut in revers are hitting something under travel?
Old 06-22-2011, 01:58 PM
Its definitely not the tires. it also does it when going forward up or down a curb. im hoping it is just a loose bolt and not any ball joints since all 4 got replace about a year ago.
thanks
Old 06-22-2011, 02:19 PM
mdhawkin's Avatar
If they are that new, and since you should not have too bad of angles on them with that kit, I am betting its a lose bolt. Not being 4wd throws out a lot of potential issues. I think if it was a wheel bearing, if it was to a point of "clunking" you would have other signs, vibration, noise while driving, heat issues and so forth. The only other thing would be a tie rod end, but I don't see why it would "clunk" under vertical movement.
Old 06-22-2011, 02:26 PM
yeah, this is the only sound the truck makes. And going up a curb with the wheels straight it wont make the sound. The noise sounds like a bolt not fully in the hole and holding on to the side of the hole with just the threads. then when you hit a bump it slams into the hole. Very loud. When i was putting my new sway bar end links on i did not see any noticeably loose bolts. i will just have to look harder tonight.
Old 06-22-2011, 02:47 PM
mdhawkin's Avatar
Some to check:
Where coilover goes into frame horn mount (3 bolts).
Not sure if that kit uses a spacer or a strut extender but check those too.
Check drop down bracket that LCA's connect to.
Check torque speck on UCA and LCA ball joints.
ALSO, may not hurt to check and make sure break caliper is bolted on securely.
Old 06-22-2011, 03:01 PM
thanks, i will check all of those. The lift kit i have is the PC stage 2 with the adjustable coilovers.
Old 06-22-2011, 04:02 PM
mdhawkin's Avatar
Thats sweet! How far cranked are they, are your control arm angles pretty level/parallel?
Old 06-22-2011, 07:57 PM
i have them cranked about 2". the control arms are down some, they look just like they would on a truck with a 2" level. Ill probably make a new thread with pics when i get my new bilstein 5125 shocks. When i cranked the coilovers i also added a 5.5" block.
Old 06-23-2011, 10:07 AM
mdhawkin's Avatar
That should not be too bad then. Let me know if you find anything loose under there.
Old 06-25-2011, 05:20 PM
mdhawkin's Avatar
Any luck bud?
Old 06-26-2011, 09:01 AM
i snugged up all the bolts and i havent heard any noises yet. the bolts on top of the coilover werent loose, but i was able to tighten them up a good amount. im going to drive it a lot more today and ill let you know if anything comes up. i do have a lot of squeaking coming from the front left. im guessing just a dry ball joint. what do you think. it squeaks over every bump.
Old 06-26-2011, 10:25 AM
thejake1989's Avatar
It could be bushings squeaking also
Old 06-26-2011, 12:14 PM
alright, I'll try to grease everything again.
Quick Reply: Pop/Clunk in front end
