Shocks - Monroe Sensi-trac vs Rancho rs5000
I don't think the other guy necessairily likes the Monroe...I think he's saying if you're set on Monroe, then go with the Reflex.
There's waaaaay better shocks out there than either one of these and you've probably read about them if you've been searching. But if you're on a budget or just not willing to spend the cash on good shocks, (or dead set on one of the two you listed for some reason) then I'd get the 5000's.
on
1 Post
I have the Monroe Reflex on the front and the Monroe Load Adjusters on the back. They have been great so far and the warranty is hard to beat.
I have had Ranchos, Bilsteins and KYBs on other vehicles. The only ones I really didn't like were the KYBs and that was because they didn't last. The ride was great but they only lasted just over a year. The Monroe Reflexes are slightly softer than the Ranchos and Bilsteins and the Sensi-tracs will be softer yet. It all depends on how firm you want your truck to ride and how much money you want to spend. IMO I would stay away from KYB but any of the other 3 would be a safe bet.
really its just a matter of personal preference. the ranchos are a stiffer ride and reflexes adjust to what surface your going over.
I probably sound like a salesman but if you want a median between the rs5000's and the bilsteins, the reflexes are the way to go
ever hear of the rancho rsx? they are now discontinued but the reflex uses the exact same design, just with different colors on the shock and under a different name
ranchos are like 54$
reflexes are around 48$ bilstiens are $70+
Monroe sensatracs are garbo....
I went through three set on my 02 and they all "clicked" after 7000km..
Take them off and one of the 2 fronts was alway pooched...
They have serious rebound issues those shocks, and would never recommend them.
Go for the monotube reflex if you go with monroe....
The RS5000's are no better, they are virtually the same thing as a sensatrac or basic monroe...
Why not just spend the extra bit and get some KYB Monomax's...
They are not particular to offroad, but are quite stiff for cornering.
It will stiffen the hell out of your ride and your truck will handle like a dream.
But I doubt you will go with them....
You sound like you don't want to spend any money.
5000's are an off road shock, so they are stiff. reflex is an on/off road shock. its like an all terrain tire. best of all worlds, but dosent take home the gold for any category. if your all road driving I would suggest the reflexes, because they are ready for anything. they are cheaper then the 5000's and Im not sure but I believe that they have a lifetime warranty
5000's have a bit bigger rod, but by no means are they an offroad shock as far as I'm concerned.
I had them on my 92 f150, and they ride like a Monoroe...
Because they are exactly the same.
The reflex's are going to be better because they are a monotube design instead of a twin tube...
Monotubes on the rear of an ORV is asking for trouble if a rock hits them....
No more up and down if they get dented...
Twin tubes have a second wall which will make for better protection....Or more like.."they willl still work if dented"
thanks for all the input, and yah i am doing shocks on a budget as you can tell by my selections. Dont want to spend the money on expensive shocks right now when there are other things more pressing atm.
i really appreciate the info, most threads are comparing high end shocks and what is "best" for off roading or such.... i just need quality on a budget.
