2" (or larger) leveling kit on 2009 - maybe not such a good idea
Old 03-06-2011, 10:11 PM
2009KR's Avatar
I put on a 2" AS leveling kit on my 2009 4x4 last year. I have posted my pictures and concerns about the extreme angle of the upper control arm earlier this year, but now have a new concern. After reading the Bilstein literature (thinking about swapping my leveling kit for a 5100 to have a little lower front end since I am going to tow a 4 ton trailer this summer), they claim an issue with leveling kits is that they prevent the strut-limiter from engaging properly resulting in suspension damage. Well, on my truck, the strut clearly no longer limits the suspension travel with the leveling kit installed. The photo below shows that my upper control arm can hit my spring (truck is jacked on the frame here).
And this photo shows the scar on the spring from the impacts it has had with my upper control arm. This is with a truck that is not driven off road.
I am removing my 1" stacked block next week and adding Firestone airsprings to level out the back, both unloaded and loaded. (Without the 1" stacked block, my front was 1/2" higher than my rear with the 2" kit.) What do you think about swapping out my 2" AS kit, which raised my front nearly 3", with Bilstein 5100's set to 1.5"?
Old 03-07-2011, 01:56 PM
Joe_STX's Avatar
I see that Daystar makes a 1" leveling kit. Do you know of anyone who has tried this? I have always felt that a 2" leveling kit puts the upper control arm at a bad angle.
Old 03-08-2011, 10:58 PM
2009KR's Avatar
The group is surprisingly quite about this. Thoughts anyone?
Old 03-09-2011, 02:35 PM
LOWCOUNTRYKR's Avatar
They must have done some serious changes because I have had 2.5" kit up front on my 2008 for 2 years now, with no impact on the springs
Old 03-11-2011, 05:52 PM
2009KR's Avatar
Does anyone have similar pictures with Bilstein 5100s?
Old 03-11-2011, 07:56 PM
hammer40's Avatar
I just put a 2.5" kit on mine and it doesn't look near that bad. Although, I don't jack it up and let the suspension drop like that.
Old 03-11-2011, 08:11 PM
dozerdog's Avatar
I've had mine on my 2006 ext-cab for a couple years,haven't had that, or any other issue. mine is an offset steel model (can't remember the brand), which is 2.5". If i remember right, the reason I chose it was because they advertised something about the above problem.
Old 03-11-2011, 09:39 PM
Big_Smokey's Avatar
i had a 3" on my 06 screw and didnt have that problem....hmmm nothing on my 10 though
Old 03-12-2011, 08:59 AM
2009KR's Avatar
Mine is the offset version from autosprings.
Old 03-12-2011, 09:26 AM
MGDfan's Avatar
I'm quiet because I'm speachless (yes, me)
All I can say is - those poor balljoints....
It never ceases to amaze me why folks will compromise the ride quality, travel, reliability and safety of their stock suspension geometry for something as ethereal as a 'look'.
There are ways to do this correctly - and that ain't it.
MGD
Old 03-12-2011, 09:51 AM
BlacKnBack's Avatar
MGD
Cause we can...
Old 03-12-2011, 09:55 AM
MGDfan's Avatar
Originally Posted by BlacKnBack
Cause we can...
Roger that! I figgered there HAD to be SOME reason
I must be gettin' old - I no longer enjoy invoking the pucker factor
MGD
Old 03-12-2011, 11:10 PM
2009KR's Avatar
MGD
Don't just leave us hanging... I suggested the Bilstein 5100s - do you think that is the correct way? At what height would you set them?
Old 03-13-2011, 09:20 AM
BlacKnBack's Avatar
MGD
Sure you do.....you just don't remember.......
Old 03-15-2011, 09:23 PM
2009KR's Avatar
Does anyone have Bilestein 5100s on an '09? What setting did you use? How do your UCA angles look compared to mine?
Quick Reply: 2" (or larger) leveling kit on 2009 - maybe not such a good idea
