Leveling Kits/Suspension Lifts/Tires/Gearing Information For 04-08
2004-2008 LEVELING KITS:
-2 1/2" Leveling Kit:
-2X4 = 33" Tires on oem rims
-4X4 = 35" Tires on oem rims
-3" Leveling Kit:
-A lot of members will agree this puts to much stress on front suspension thus causing parts to wear prematurely.
NOTE: You can fit 35's on aftermarket wheels that are 8" wide with atleast 5.5" of backspacing with minimal trimming with a 2.5" level.
2004-2008 BODY LIFTS:
-3" Body Lift:
-Performance Accessories
-4X4- 35's
-2X4- 33's
-Kit- $350
-Install- $600-$1000
NOTE: Both come W/ bumper relocation brackets and everything you need for the installation
2004-2008 LEVELING KIT W/ BODY LIFT COMBINED:
-2 1/2" Leveling Kit W/ Body Lift:
-2X4 = 35" Tires
-4X4 = 35" Tires
2004-2008 SUSPENSION LIFTS:
-4" Suspension Lift:
-4 Inch Suspension Lift
-Rancho
-BDS
-Rough Country
-4X4 = 35" Tires
NOTE: You can fit 35X12.50 or 35X13.00 Tires on 4X4 unless you have a wide wheel ( 10inches ) W/ Shallow Backspacing ( 4.5inches )
-Rancho you can re-use stock wheels
-6" Suspension Lift:
-6 Inch Suspension Lifts:
-Fabtech
-BDS
-Procomp Stage I&II
-Skyjacker
-Rough Country
-2x4= 35" Tires. Possible rubbing depending on backspacing
-4x4= 35" tires. Possible rubbing depending on backspacing
-8" Suspension lift:
-8 Inch Suspension Lifts:
-Rize
-4x4= 37's
NOTE: With the Rize Lifts it may require some heavy modification
-Lengthening Driveshafts Front/Rear
-Brake Lines
-Custom Shocks
-Custom Leaf Packs
-Upgrade Brakes If Possible Due To The Tire Size
-12" Suspension lift:
-12 Inch Suspension Lifts:
-Rize
-4x4= 40" tires
-Brake Lines
-Custom Shocks
-Custom Leaf Packs
-14" Suspension Lift:
-14 Inch Suspension Lifts:
-Whiplash
-Full Throttle
-4X4= 40" Tires
-2X4= 38" Tires ?
NOTE: This kit requires you to buy an aftermarket swaybar,bushing and clamps for an additional $175
2004-2008 ADDING ONTO A SUSPENSION LIFT:
- 2"-2 1/2" Leveling Kit on top of your existing suspension lift
EXAMPLE: Pro Comp Stage I&II, BDS, Skyjacker, Rize, Fabtech
-Adding a 2"-2 1/2" Leveling Kit you can fit bigger tires all depending on backspacing
NOTE: May have to do some minor trimming due to rubbing issues
-Adjustable Shocks = Adjustable shocks replace your oem strut(shocks) and can be adjusted from 0"-2" Inches of lift
NOTES: YOU CAN USE ADJUSTABLE SHOCKS AND LEVELING KITS TOGETHER ONLY IF YOU USE THE ADJUSTABLE SHOCKS AT THE 0" SETTING
-Coilovers = You can upgrade your factory strut assembly with coilovers from King, FOA, Pro Comp
NOTE: Coilovers can replace the Leveling Kit/Lift Spacer and also be cranked up to 2inches
2004-2008 REAR SUSPENSION LIFT OPTIONS:
-Bigger Block In The Rear
-Shackle Lift
-AAL
-Leaf Packs
-Deaver, Atlas, National Spring
NOTE: AAL will stiffen up your ride but better for towing
-DO NOT stack blocks in the rear
2004-2008 GEARING:
-Front 8.8 Reverse Cut
-Rear 9.75
NOTE: Not All 04-08 have the same rear axles.
-35" Tires = You can leave stock gearing but if you choose to change you should 4.56s
-37" Tires = You Will need to Re Gear as soon as possible to 4.56s or 4.88s
NOTE: Price for 4X4 Gears/Install varies. But you can expect to pay $1400-1900 Parts/Labor
-Gearing Needs to be the same Front/Rear in order for the 4X4 to work properly
2004-2008 RIMS:
-Smallest size is 17"
2004-2008 TIRES:
-BFG All Terrain
-BFG Mud Terrain
-BFG KM2
-Toyo Mud Terrain
-Nitto Mud Grappler
-Nitto Terra Grappler
-Nitto Trail Grapplers
-Toyo All Terrain
-Kumho Mud Terrain
-Procomp
-DC
-Micky Thompson
-Cooper Discoverer ST & STT
SOME PLACES TO BUY THINGS FROM:
-Alon At Modbargains.com
-4 Wheel Parts
-4 Wheel Online
-Truckaddons.com
-Offroadunlimited.com
-Suspensionconnection.com
-Topguncustomz.com
-Local Truck Shops
RESOURCES AND THREADS ON THIS FORUM THAT CAN HELP:
- https://www.f150online.com/forums/20...2-5-level.html
NOTE
Mods can we get this a sticky for this when it is completely finished??? I think a lot of members when think this is helpful. I want to put more info in this before it becomes a sticky or you can go ahead and make it a sticky if you think it looks good enough. But other members if you feel something needs to be added in here please put it down and i will do my best to add it in there. Thank you guys for your help and im hoping this thread will become a sticky to help some of us out. Also half this info is from 06yz250f so thank you for providing half the information.
Thanks guys
-3" Leveling Kit:
-3" Body Lift:
-4X4- 35's
-2X4- 33's
-Kit- $350
-2X4 = 35" Tires
-4X4 = 35" Tires
-Rancho
-BDS
-Rough Country
-4X4 = 35" Tires
-Fabtech
-BDS
-Procomp Stage I&II
-Skyjacker
-Rough Country
-Rize
-4x4= 37's
-Brake Lines
-Custom Shocks
-Custom Leaf Packs
-Rize
-4x4= 40" tires
-Brake Lines
-Custom Shocks
-Custom Leaf Packs
-Whiplash
-Full Throttle
-4X4= 40" Tires
-2X4= 38" Tires ?
-Shackle Lift
-AAL
-Leaf Packs
2004-2008 GEARING:
-Rear 9.75
2004-2008 RIMS:
2004-2008 TIRES:
-BFG All Terrain
-BFG Mud Terrain
-BFG KM2
-Toyo Mud Terrain
-Nitto Mud Grappler
-Toyo All Terrain
-Kumho Mud Terrain
-Procomp
-DC
-Micky Thompson
-4 Wheel Parts
-4 Wheel Online
-Truckaddons.com
-Topguncustomz.com
-Local Truck Shops
NOTE
Thanks guys
i would just wait until you got your 35s to re gear if even then
