Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 02-19-2010, 01:58 AM
Garage is empty, add now
Vehicle: 2008 Ford F-150
Problem ?
Hey everyone!
I have just installed a 2" AS leveling kit on top my 6" Pro comp stage 1 suspension lift on my 2008 F150. (have been told by some members that have done this have had very good luck with there's) I have also have 8" total in my blocks in the rear. Basically giving me 8" all around. My questions and problems that I am having are. My drive shaft looks like its really being pulled out along ways from the transmission. Also I am getting kind of a grinding / squealling / clicking noise from the front passenger tire area. I can not totally pin point it. Here's the "KICKER" It will only make that noise in 2wd not in 4x4. I will also not always there, but very very often (drive like 10ft without hearing it, then it will be there for like 100ft and go away again).If anyone can help me with this issue it would be much appreciated! Also some of you guys that are running 6-8 in the rear, what are you doing for your drive shafts? (spacer? , new? etc?)
Thank you Derek
Old 02-19-2010, 11:32 AM
2009 Ford F-150
Vehicle: 2009 Ford F-150 FX4
djn79 djn79
well for the drive shaft problem you could get a spacer for it depending how far it is out
I need help...
Old 02-19-2010, 11:36 AM
2005 Ford F-150
Vehicle: 2005 Ford F150
Send a message via AIM to mhockey9090
^ I agree. Also do you have any pics of your driving shaft and how much its pulled out
Old 02-19-2010, 01:07 PM
Vehicle: 2005 ford f150
There was a thread a while back discussing this. The member used a procomp spacer and it did the job. Also you have to use the correct shim to flatten the axle back down.
Old 02-19-2010, 02:28 PM
2009 Ford F-150
djn79 djn79
Quote:
yeah some pics would be nice just make sure a spacer will help the problem
Old 02-19-2010, 04:53 PM
2004 Ford F-150
Vehicle: 2004 FORD F150
Send a message via AIM to MUD DIGGER
I'M looking in to doing this i would appreciate some pictures as well.. thanks, also if you could post some pics of the spacer on
Thanks Watson91 for The Sig!
2004 Super Crew Flomaster, 6in Procomp lift Gryphon 18x9" Procomp Extreme Alloy 1079 325X65R18 TOYO Open Country AT, Crome Sports bar KC lights MP3 CB K&N CAI PROCOMP skid plate Procomp light bar Rhino lined bed Tow Nutz, LED Tailgate Bar, Bug Shield Carbon Fiber Dash Kit, 2 12" Pioneer TS-SW1201S2 Shallow Sub Woofers, Sony CDX-GT630UI HeadUnit 5901 Viper Alarm system Deleted Rear Cats Magnaflo hiflow 2 front cats
Old 02-19-2010, 05:37 PM
Hey guys sorry I dont know how to post pics on this forum, as far as I can tell there is no attach area!
2008 Ford F-150 FX4 Plus, Super Crew, dark blue with black leather interior, 6" Pro Comp stage 1 lift, 2" Auto Spring level, 8" Total, 37x13.5x22 Kumho MT, 22" Fuel Hostage wheels, Bushwacker pocket fender flares PTM, 3" Magnaflow exhaust, N-Fab nerf bars, Black badges, Powder coat skid plate and billet grills, Headlight and fog light HID 6000k, 28% window tint all around with eyebrow. Tinted taillights and 3rd brake light.
Old 02-19-2010, 10:57 PM
2004 Ford F-150
this is what you can do... go to tinypic.com upload the pic and take the link that says message bored and copy and paste it here and the pics should show up well thats how i do it
Old 02-19-2010, 11:04 PM
2004 Ford F-150
here is a proto type Click the image to open in full size. just copy and paste the link like this... i woudl really like to see what it looks like, srry for spelling kinda drunk right now but here ya go
Old 02-20-2010, 04:31 AM
Here are some pics I hope they work! Also just to let you guys know I have figured out the grinding sound in the front passenger side. One of my vacuum hoses came off on the drivers side for the 4x4 auto locking hub. (Sound completely went away) Also I have measured the big ring on the drive shaft to the trans. (The slim area where the shinny part is in the pics.) I am getting a measurement of 3 1/2". I have also measured a truck in town with a 8" Rize lift, he is running a 6" block under the factory block and is right around the 3 1/2" as well. I have talked to a local shop in town that installs these Rize lifts and say they never put a spacer in any of there trucks, and they say they are fine? Just dosn't look right to me. I have also attached a pic of my CV angle.
http://i762.photobucket.com/albums/x...x/SDC12754.jpg
http://i762.photobucket.com/albums/x...x/SDC12756.jpg
Old 02-20-2010, 10:21 PM
Bump....
Old 02-21-2010, 02:48 PM
2009 Ford F-150
djn79 djn79
i dont know if a spacer is goin to fix the problem, your drive shaft looks pulled out far, and ur cv's r at a really bad angle
I need help...
Old 02-21-2010, 02:58 PM
fx4 for life 79 if you are running the Bilsteins (guessing they are the 5100) with your 6" suspension lift for 8" total, you should have the same angle on your CV axles should you not? They still push down your lower control arms to achieve your 2" extra lift! What lift setup are you running in the back of your truck? (add a leaf?, more blocks? total height in rear?) Could you post pics of your CV angles plz?
Thanks Derek
Old 02-21-2010, 03:14 PM
2005 Ford F-150
Quote:
not to hijack but did you use the bilstein 4-6 inch lift shocks or the 5100 adjustable ones up to 2inches with your procomp lift? Do you still have the procomp spacer or no lol
Old 02-21-2010, 03:23 PM
2005 Ford F-150
Heres mine and im running 6inch skyjacker and a 2inch leveling kit. You can see how far mine is pulled out and is no where near what yours is. My rear setup is 6inch leaf packs in the rear and a 2inch block
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
