Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 01-24-2010, 12:44 PM
2000 Ford F-150
Vehicle: 2000 Ford F150
Question body lift vs suspension lift?
body lift vs suspension lift? - why would you choose one over the other?
i know body lifts tend to be cheaper than suspension lifts, but suspension lifts can give more speed over the rough due to the increased vertical range of travel of the wheels... what else?
thanks for your time
jg
Old 01-24-2010, 09:08 PM
Garage is empty, add now
Vehicle: 2005 FORD F150
level it instead of body lift. cheap, up, and factory ride. best of all worlds.
but if you go higher, suspension all the way!
5.4 3v-4.56 LSD-JLT ram air-sct xcal2-long tube headers-Maggie high flow cats-Cherry bomb extreme exhaust-315/70R17 BFG A/T's-2.5" hell bent steel level-1.5" RL rear block-clarion 7" screen-6x8 polk audio's-10"mtx sub w/500 mono block amp-
http://www.youtube.com/watch?v=rhWTil7QCF0 http://www.youtube.com/watch?v=kV1si9veSoc
Old 01-24-2010, 09:54 PM
Vehicle: 2001 ford f150
Most suspension lifts do not add any wheel travel.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
Old 01-24-2010, 10:06 PM
2000 Ford F-150
aha
Quote:
i did not know that. i just assumed the reason for the suspension lift was to allow for that increased travel.
so all a suspension lift gets you is more room for the bigger tires, and the necessary suspension capacity for the added weight then?
Old 01-24-2010, 10:29 PM
2006 Ford F-150
My Garage
Vehicle: 2006 Ford F-150
body lifts simply raise the body up up to 3in.s for clearance of bigger tires.
suspension lifts raise up the frame, engine, and everything else thats between the rear axle and the ifs stuff up front. this allows clearance for tires and also clearance of the frame on the ground so you don't get stuck sitting on the frame.
Old 01-24-2010, 10:31 PM
2000 Ford F-150
Quote:
Originally Posted by 05crewzer View Post
level it instead of body lift. cheap, up, and factory ride. best of all worlds. ...!
i keep hearing about cv issues with leveling kits. can i assume there are no problems in leveling a 2WD?
and, i think i've read that a level kit should never be combined with a suspension lift - is that correct?
Old 01-24-2010, 11:14 PM
2005 Ford F-150
Vehicle: 2005 Ford F150
Send a message via AIM to mhockey9090
theres numerous members here running suspension lifts with a 2-2.5 inch leveling kit on top of it.
Old 01-25-2010, 10:08 AM
Vehicle: 2004 Ford F-150
Leveling it is not going to give you the lift that your wanting. Leveling kits only raise the front to "level it with the back". Dont get me wrong a leveling kit is a must for these trucks, looks so much better leveled out, but its not a lift. Nothing wrong with a bodylift if its done right. Their cheaper and you'll be able to maintain your factory ride. The downside is installation. If you can do it yourself you'll save some big bucks. If you pay a shop to do it than your looking at some big bucks, cas these model trucks are a PITA to install.
If money ain't a issue though, then I would get a suspension lift. Do a search on bodylifts and looks at some pics. Also, compare it to a truck that only has a leveling kit........big difference.
2004 XL 5.4, 4x4
Bilsteins 5100's, 295/70/17 Nitto Grapplers, 17x8 Eagle Alloy 137's , power windows and locks, XLT console
Old 01-25-2010, 09:33 PM
2wd no issues although many members recommend not using higher than 2.5 so the ball joints don't bind. don't quote me on this but some also say you can with some suspension lifts but not all.
right a suspension lift will give more lift which is sooo nice but more costly. but comparing a level kit with a body lift just doesnt work. level the front and use 1.5 to 2 inch to lift the back and your close to the same height but with much more ground clearance. this is something anyone can install in a few hours. or do both. probably the best idea.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
