No. In my self-built 28 x 32 clear span shop/garage (two story). You sound a bit doubtful
of outcome. First off, I want to thank you for your reply. It had the info that I couldn't find, to get me started. BUT...
I did do 7 yrs as flat-rate auto body/frame tech at a dealership (back when it was mostly bubble gauges and tape measures -- we had to pull to within less than 1/2 of the factory tolerance before the foreman would release to the wheel alignment tech). Still have same tools. I worked on a 50/50 rate split with the shop. The shop charged customers $8.25/hr labor and was considered a more expensive shop for the city at the time. Also drove long-haul reefer's and was a manager (8 yrs) at an auto and motorcycle dealer. Then 25 yrs as civilian Senior Test Director (testing and redesigning Material Handling & Construction Equipment and Automotive testing) at Combat Systems Test Activity, US Army Aberdeen Proving Ground. Been retired awhile now and just needed some specs and some good help
(which you provided) to kick start my senile memory bank. This is my first 4WD truck, though.
Apology for the rant Patman, bad day & needed to vent.
Besides, per first post I said I wanted to pre-check (so I know where it's really now set, before I took it to a shop maybe as rip as the previous one) and
possible adjust
