F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Thread Tools Display Modes
Old 10-22-2009, 12:04 PM
Vehicle: 2001 Ford F150
Add-a-leaf?
Hey guys, I was considering doing a 1 or 2 inch body lift in the rear only to level my truck out, but I saw in someones sig about a 2" add-a-leaf lift? Do you guys have opinions on this and do you think it would be sufficient on my truck?
Thanks in advance!
Old 10-22-2009, 12:11 PM
Vehicle: 2004 Ford F-150
I would deff. do an AAL to get the rear from sagging. A body lift cannot be done to only half of the truck, if you do the bed will raise up and the truck will look worse than sagging.
PHP Gryphon, 2.5" AS level, Strobes on all 4 corners, Black TS Toolbox, 15% tint all around, Pioneer AVH-P4100 with Low_e_red's relay bypass, MA Audio 1000w RMS 1 ohm amp pushing 2 - 10" ED subs under the rear seat, Viper 5901 with 530T auto up/down windows, Viair 380c at 165/200 PSI in a 3 gal tank pushing 1/2" DOT airline to my Siege Engineering train horns, and Beltronics RX 65 pro to keep me out of trouble
Old 10-22-2009, 12:14 PM
What do you think, 2"? And you guys recommend using pro comp?
Old 10-22-2009, 12:20 PM
Disregard that last one - I see now that you buy the kit and it adds between 1.5 to 2.5 inches. I am curious if the prev. owner had it like this to avoid rubbing on the front tires when turning sharp...
Old 10-22-2009, 02:56 PM
Vehicle: 2006 Ford F-150
Quote:
well first off a body lift is a series of spacers that lift up the cab and the bed of the truck off the frame so this will do nothing for sagging.
raising the height of the rear will not make it rub on the front just fyi
6in. Fabtech, 3in. body, 38in. toyo opencountry m/t, 20in. moto metal 909, straight pipped exhaust, edge evo programmer, 2 12in kicker cvr's, 750.1 kicker amp, streetglow, bushwacker flares, westin bull and step bars, hella 500 lights in grill, piaa 510's in fogs, 6000k hid's in all lights, black heads and tails, t-rex black billet grill, custom fx4 monster stickers, black badges, train horns
Old 10-22-2009, 03:25 PM
Vehicle: 1994 Ford F-150
Send a message via Yahoo to twlightning
I have the add a leaf on mine. Bought it of eBay from sandyriver (something like that) it came in a pro comp box with my torsion keys. Can't say it added two inches. Prob 1/2 to 3/4 inches. It is nice for towing and doesn't change the ride a lot. If I was you I would just buy some 2 inch blocks and longer U-bolts. BTW nice truck!!!
Old 10-22-2009, 03:42 PM
Vehicle: 1998 Ford F-150
what is the current setup in the rear now. cuz you can get AAL that do a range but not guarenteed to do a certain amount of lift
thanks dirtyd88 for the sig
98' Extended Cab Blue/Blackout
rebuilt 4.2, 5 speed, "Gotts" intake mod, K&N Drop in,
Rhino-lined Rockers and bumpers and N-Fab Prerunner light bar with Hella 500 Lights
1.5" daystar leveling kit
Dynomax Bullet exhaust
285/75R16 BFG KO's
Pioneer premier sound system with 2 Kicker 10's, CB w/PA.......
Transformation Thread
Old 10-22-2009, 05:10 PM
I'll be honest - I got it from a dealer and I am not really sure what the lift is. I am just getting into all this stuff but I'm eager to learn. So if I took some pics do you guys think you could identify some stuff? I know I have Rancho shocks, and I saw some blocks in the u-bolts. Thats about all I can answer.
Old 10-22-2009, 05:46 PM
It sounds like you already have a block and aal kit back there. Are there any markings on the front cross member? Can you take a close-up pic of the compression strut brackets? That might tell us what lift kit you have. FYI, Rancho makes kits, but that does not mean it's a Rancho lift, lots of people run Rancho shocks with other lifts.
Old 10-22-2009, 05:54 PM
I'll get the pics as soon as my wife comes home with the camera in a couple hours. I don't think I have a AAL because there are only 4 leaf springs... Sounds normal?
Old 10-22-2009, 06:01 PM
XL34-5059-DA is all I see stamped on my Crossmember. I believe it's a fabtech lift because on the bar (looks like a crossmember but farther back) where my torsion bars connect into has a fabtech stamp on it. Also the (what I call a deer catcher) brush guard on the front has a 1/4 inch thick steel plate that has fabtech cut out of it. So I guess it was a fabtech lift with Rancho shocks. My question is if he already has AAL on the back and it still sags this low, what the heck is wrong? lol I will still try and get pics in a couple hours.
Old 10-22-2009, 08:50 PM
Here is the pics, if you need a different angle or whatever just let me know...
Thanks in advance guys - any insight you can give... If AAL is the way to go I will get all over that.
Old 10-23-2009, 10:21 AM
I think there are two options. One is replace the block in the rear with a bigger one. Another option that might be easier to lower your torsion bar keys. This will level it out and make it ride smoother. Just make sure you have enough room to flex and turn. I'm thinking the keys are cranked up and posibly could have a aftermarket set installed. Just check the bolt on the torsion key so see how far it is threaded in. Also if you go that route, you will probably need an allignment.
Old 10-23-2009, 10:38 AM
Ok from that response - if I did a larger block would that be a standalone change or would it drive other maintenance, and as for the torsion keys I don't want it any lower I prefer the back to be raised to level but I appreciate that input.
So why add a larger block and not add-a-leaf?
Old 10-23-2009, 10:54 AM
I just measured my block and its 3 in. tall and 2.5in wide. Do you think that a 5 in lifting block would be safe and that my current rear shocks can support it?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
