F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Thread Tools Display Modes
Old 10-07-2009, 11:16 PM
Question about CoilOvers
Simple question if those with them dont mind helping answer. Some of you know I have an 09' with a 6" BDS sus lift, and a 2" BDS spacer kit for a total of 8" in the front. Im looking to replace the front strut and spacer kit with CoilOvers instead.
So, what size coilover do I need as in length ? King has released an OE replacement system for the stock 09' that is 2.5" adjustable. The BDS kit comes with replacement struts but uses the stock coil which may and or may not be longer than the stock ones, but if they were, the King's would not work as I would still need a spacer to achieve the 8"
Would the pro-comp coilovers that come with there 6" kit be the best bet and simply crank them up 2" ?
Needing the F150 gods to help direct me =)
Old 10-08-2009, 12:09 AM
Vehicle: 2004 ford f150
That would not work, just like you said that is for a stock truck to level it out, basically its a badass leveling kit almost. Thats what I did, I actually have a procomp kit and bought the fabtech dirtlogic coilovers and cranked them up 2", procomp coilovers will fit even though you have a different lift. Hope this helps any
2004 Ford F150 Supercrew 4x4,6" Pro Comp Suspension Lift,3" PA Body Lift,2" Rear add-a-leaf,38" Toyo Mud Terrains,18" Moto Metal 951,HarleyDavidson Grille,Fabtech Dirt Logic 2.5 Coilovers Cranked 2 Inches,Rear Pro Comp Mx2 resovoir,Amp Power Research Steps,ATS Fender Flares,Mag-Hytec Differential Cover,Rize 6" Rear Blocks,Omega Triple Trumphet Train Horns
Old 10-08-2009, 12:21 AM
Thank you sir!
Old 10-08-2009, 01:24 AM
No problem man.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
