F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Thread Tools Display Modes
Old 08-04-2009, 06:28 PM
Vehicle: 1996 Ford f150
death wobble?
i recently acquired "death wobble". every time i hit a bad bump in the road my truck shakes vigorously until i come to a complete stop. i'm planning on a solid axle swap but i'm just waiting on parts and the time to do it. but does anybody have any suggestions of what i can do to possibly prevent the shake? i changed out the steering stabilizer and my ball joints and wheel bearings are fine.
Old 08-04-2009, 10:37 PM
Vehicle: 2006 Ford F150
Send a message via AIM to BlueScrew150 Send a message via Yahoo to BlueScrew150
Welcome to the site.
I had about the exact same problem in my Cherokee and a new steering stabilizer solved it. Was it much improved after the new stabilizer? Or, did you even have the problem before you got a new stabilizer?
  • 2006 XLT 4x4; 5.4L V-8; 3.73 LS; 150" W.B.; Troyer Tuned XCal 2;
    AS 2.5"; Aux Input via FMMOD01; Electric Tailgate Lock (woohoo!);
    and some ERG In-Channel window vents.
Old 08-04-2009, 10:57 PM
Vehicle: 2007 Ford F150
I heard that even an alignment can fix this. But you covered all the basics, ball joints, bearings, tie rod ends, stearing linkage. How much lift do you have and what setup?
Old 08-04-2009, 11:58 PM
i have a six inch rough country, i know it's cheap but i was on a budget build, and a 3 inch body lift. currently riding 35 12.5 baja claws. the problem started and then i changed the stabilizer, went away for about a week and a half or so then came back. i replaced the stabilizer with a skyjacker dual stabilizer.
Old 08-05-2009, 12:27 AM
Vehicle: 2007 ford edge
try getting an alignment. my buddy had the same problem in his grand cherokee and that fixed it.
Old 10-07-2009, 10:00 PM
Check out this article
http://www.4wheeloffroad.com/techart...ure/index.html
Old 10-08-2009, 03:50 PM
Vehicle: 2009 Ford F-150
Quote:
I have an 05' F250 Super Duty (my company truck) that has MAJOR problems with this. When driving on the highway and turning either slightly left or right and hitting an expansion joint in a bridge, my truck would shakes so bad I need to pull over... The weird thing is it's intermittently happening, usually when I least expect it.
Check this link out..
http://www.topix.com/forum/autos/for...P1M75VBFBFT9IL
Old 10-10-2009, 07:07 PM
Vehicle: two 2003 F-150s
Send a message via AIM to Patman03SprCrw
what about tie rods?
Old 10-10-2009, 07:32 PM
Did you change anything right before this started or was it just 'out of the blue'?
Old 10-10-2009, 08:18 PM
Send a message via MSN to Paralyzer
if the front end components are all tight I would check the alighnment sounds like a caster issue.
Old 10-10-2009, 08:42 PM
Vehicle: 1995 ford f150
i had this problem on my truck, basically every bushing or joint was worn out and had about 1/16th to 1/8th inch play in all components. here's what i had to replace:
axle pivot bushings
upper and lower ball joints
drag link ball joints
also rotated and balanced the tires
and checked wheel bearings
'95 F150 XLT reg cab long bed, swapped in 5.8L, 147k miles, built 4R70W, 3 inch P.A. body lift, 6 inch Rough Country susp. lift, 35X12.50 MTZ's, 15X10 DC-1's, Pacesetter shorty headers Magnaflow pipes and high-flow cat, Flowmaster Super 44, K&N intake, Optima red-top, clear lenses, white faced "glow" gauges... may the 302 R.I.P. gear swap is next!
Old 10-11-2009, 12:57 PM
Quote:
just randomly started one day. first time ever got it went over a railroad track
Old 10-11-2009, 12:58 PM
Quote:
axle pivot bushings
sounds like you had some fun with your truck too. thanks though i'll check all these things out
Old 10-11-2009, 01:26 PM
Vehicle: 1998 Ford F150 4x4 5.4L
It's called "bump steer", everything can be tight in the fornt end and you can still get this. - Find a shop that aligns the old fashion way. - W/paint and/or chalk. Laser alignments aren't worth a damn dime IMO. - For our 4x4 models anyway.
Search "Ford bump steer problems"
Old 10-11-2009, 02:23 PM
Quote:
I guess we shouldnt use computers to tune the engine either, we will just tune it by how it sounds/feels
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
