6" Skyjacker install, 2 weeks later I have issues?
So yesterday I was going to work, hit a bump, compressed the front suspension pretty good and I got a vibration. I can feel it on the floor, the steering wheel, the brakes, and the gas pedal. I get it in 2wd, switch to 4wd and it changes how it feels. I removed the front driveshaft and it is gone completely. The U-joints all feel good, could it be my transfer case? With the front driveshaft removed, I stopped, engaged 4wd and it still didn't make any vibrations? One thing skyjacker doesn't do that I read other kits do is re-clock the driveshaft.
Has anyone had issues like this? Why would this start now and not earlier?
I am going to replace 1 u-joint because though it feels good, it is a little tight, maybe it is applying enough force to produce a vibration.
Turned out to be the IWE, just happen to fail around the same time as everything else. I am at 37,000 miles, going to the dealer on Monday to see if they will fix this as well as inspect the hubs since I am sure they are toast, even in 4x4 now it continues to make the noise.
PHP Gryphon, 2.5" AS level, Strobes on all 4 corners, Black TS Toolbox, 15% tint all around, Pioneer AVH-P4100 with Low_e_red's relay bypass, MA Audio 1000w RMS 1 ohm amp pushing 2 - 10" ED subs under the rear seat, Viper 5901 with 530T auto up/down windows, Viair 380c at 165/200 PSI in a 3 gal tank pushing 1/2" DOT airline to my Siege Engineering train horns, and Beltronics RX 65 pro to keep me out of trouble
The cause was from a solenoid that actuates the IWE. The solenoid has failed not allowing vacuum to disengage the hubs. There is a TSB out for 2004-2006, this is what I am asking Ford to fix, along with checking out the IWE's to ensure they were not damaged.
