Sponsored by: CARiD
6" Skyjacker install, 2 weeks later I have issues?
Old Jul 3, 2009 | 01:09 PM
mrpositraction's Avatar
So yesterday I was going to work, hit a bump, compressed the front suspension pretty good and I got a vibration. I can feel it on the floor, the steering wheel, the brakes, and the gas pedal. I get it in 2wd, switch to 4wd and it changes how it feels. I removed the front driveshaft and it is gone completely. The U-joints all feel good, could it be my transfer case? With the front driveshaft removed, I stopped, engaged 4wd and it still didn't make any vibrations? One thing skyjacker doesn't do that I read other kits do is re-clock the driveshaft.
Has anyone had issues like this? Why would this start now and not earlier?
I am going to replace 1 u-joint because though it feels good, it is a little tight, maybe it is applying enough force to produce a vibration.
Old Jul 3, 2009 | 09:38 PM
Turned out to be the IWE, just happen to fail around the same time as everything else. I am at 37,000 miles, going to the dealer on Monday to see if they will fix this as well as inspect the hubs since I am sure they are toast, even in 4x4 now it continues to make the noise.
Old Jul 3, 2009 | 09:40 PM
31 YNOT's Avatar
Sorry to hear your having problems Gerg, but whats the IWE?
Old Jul 3, 2009 | 09:47 PM
c-huck's Avatar
yea whats iwe?
Old Jul 3, 2009 | 10:19 PM
yetti96's Avatar
Integrated Wheel End, search...
Old Jul 4, 2009 | 12:03 AM
The cause was from a solenoid that actuates the IWE. The solenoid has failed not allowing vacuum to disengage the hubs. There is a TSB out for 2004-2006, this is what I am asking Ford to fix, along with checking out the IWE's to ensure they were not damaged.
