F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Thread Tools Display Modes
Old 07-02-2009, 02:58 PM
Vehicle: 2008 ford f150
You said you have a 6 " procomp , doesnt the upper control arm get replaced with that? If not looks like you need that done to fix the ball joint.
Old 07-02-2009, 02:59 PM
Vehicle: 2004 Ford F-150
Send a message via AIM to Tyler33
And look how close your UCA is to the strut. I wonder if it hits under normal driving conditions. My 6" RC causes the UCA to hit the strut when there's no weight on the suspension so you can imagine what another 2.5" will do.
Old 07-02-2009, 03:29 PM
Vehicle: 2007 Ford F-150
With noly 6" lift yes the warranty should cover the ball joints being that there not under anymore stress than they are from factory height. Also Ford uses the 6" Procomp Stage I lift on there trucks that they lift and sale. A Ford service tech told me that warranty will cover anything unless they can prove what you added to the truck cause that part to fail/brake. And it's quite easy to see that if my ball joints went out that the extra 2.5" lift will cause extra stress on them.
I haven't had an rubbing issues with the extra 2.5" lift. It's not as close as it looks in the picture. Would have to get a better view from the side. Procomps kit doesn't come with aftermarket Control Arms.
Old 07-02-2009, 04:13 PM
Vehicle: 2006 Ford F-150
id go with a 2in. spacer instead and sell the 2.5 or get a body lift. btw ford uses fabtech also.
6in. Fabtech, 3in. body, 38in. toyo opencountry m/t, 20in. moto metal 909, straight pipped exhaust, edge evo programmer, 2 12in kicker cvr's, 750.1 kicker amp, streetglow, bushwacker flares, westin bull and step bars, hella 500 lights in grill, piaa 510's in fogs, 6000k hid's in all lights, black heads and tails, t-rex black billet grill, custom fx4 monster stickers, black badges, train horns
Old 07-03-2009, 04:00 AM
Vehicle: 2005 Ford F150
I wouldn't worry about it. I've clocked around 30K so far at or around the same angle or worse. I've yet to have any problems that everyone talks about and how my truck is going to blow up.... haha.. kind of comical. When and if it does I'll let you know.
Sway-a-way told me as long as you have around 2 inches of droop you'll be fine. You should see the angles on some long travel trucks. They will make these angles look silly.
Old 07-03-2009, 10:42 AM
Vehicle: 2005 ford f150
ill take some pics of my ball joints and cv's so you can compare the 2
Pro Comp lift w/bilsteins for 8", Pro Comp 6001 Wheels, Borla Truedual Exhaust,
325/70/17 Nitto Terra Grapplers, Superchip Programer, Tint, UWS Tool box
Exhaust clip: http://www.youtube.com/watch?v=sEd_i...e=channel_page
Old 07-03-2009, 02:02 PM
I've only heard of maybe 2 or 3 guys on here who have had to change there ball joints, but they also had 50k+ miles on there trucks with the lift. For as many people who are running this setup with either 2.5 " or 2" added to there 6" lift there aren't many having issues. I may buy the Bilsteins though just to drop down to 2" instead of 2.5" just to be safe. I'm pretty set on going back to 35's only b/c I don't want to change my gears yet. I have a few options. I still have the Terra Grapplers. Also I would like to get the Toyo MTs if I can. I'll see whichever will be the easiest and not cost me any more $$ out my pocket.
Old 07-03-2009, 02:07 PM
Vehicle: 2004 ford f150
Send a message via AIM to Jditta
Quote:
My angles looked exactly like yours do now when i had the 6" spacer and bilsteins.
Justin
Old 07-03-2009, 02:11 PM
Quote:
Do you mean that fords come from the factory with the fabtech lifts? I have only seen them with procomp lifts.
Justin
Old 07-04-2009, 07:38 PM
This is the issue i am having right now, I read so many mixed reviews on this, I am thinking about going to the Blistens so i can do 2" with the 6" RC, and an AAL
United States Air Force
Operation Iraqi Freedom 07 & 09
07 FX4 SCREW, 6" RCX, 35" BFG KM2, Gryphon
18" Moto Metal 954 (4.5 B/S)
JVC KW NX 7000
Roush upper/lower grill
Old 07-05-2009, 05:52 PM
here is a pic of my cv's, i need to get a better one of my ball joints
Old 07-05-2009, 09:35 PM
Quote:
Your CV's are at less of an angle than mine. I would appreciate if you can get a pic of your ball joints. If going from 2.5" to 2" makes that big of a difference I may do that. My CV angle doesn't worry me as much as my ball joints do. Are the Bilsteins only adjustable as stock or +2", or can I adjust them to +1?
Old 07-05-2009, 10:12 PM
i am not to sure on the 1" setting
Old 07-06-2009, 09:48 AM
Quote:
How do your ball joints look with just the 2.5" leveling kit?
Old 07-06-2009, 11:56 AM
I guess they dont look too bad, Im not the most educated when it come to this but wouldnt a 2.5" be the same angels with or without a Lift on it or does it cause more of an angel to it while lifting the suspension? I think a 1.5 AS and a 1.5 AAL on the 6" would sit nice.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
