Leveling kit install guestions for an 09 F-150... Ran into a problem
Hey guys,
tried installing my AS 2.5" leveling kit yesterday and I didn't fair so well. I am quite mechanically inclined mind you. Everything went very smooth up to to part where I tried to reinstall the strut with the spacer on top.
I did one of these kits on my dads 05 with no trouble. The only difference i can see is the design of the lower control arm. On the 04-08's, the lower strut mount in an open design, where there are 2 ear pieces that stick up where the bottom of the strut mounts. on the 09's, the strut sits down into a pocket or welded cup where the tabs are fully surrounded.
My problem was getting the strut into this pocket. With the spacer installed on the top of the strut, and this top section inplace in the strut tower I did not have enough downward rotation (travel) in the the control arm to allow for the strut to get into this pocket. I didn't have anything to compress the strut (or i would have) and didn't have another set of hands to assist with jamming it in. I needed about 3/16" to a 1/4" more rotation for this to get in there. I wish i took a pics or 2 to help describe my issue. Also, i did measure the shim and it is 1-5/8" so it is a 2.5" kit.
Anyone who has done this care to share or input on my problem? If this went in smooth it would not take me any more than 1.5hours to complete the entire job.
Thanks in advance,
Have this posted in the 09 section too, but thiought i would add it here for a little more exposure.
Thanks in advance,
Alright, thanks guys. I have a few more things to look at now. Have a buddy on stand by when i find some more time to monkey around with this.
I never noticed the break lines as a problem,, but the CV's seemed to be the limiting factor i am pretty sure. Its just getting it into this enough rotation out of the CA to allow the shock to clear the pocket hump and get to the mounting hole. Guess I'll have to use a little more muscle or rent a spring compressor as wandell said. It'll happen though.
Thanks again.
Thanks again.
