Bs?
in my judgement im going to say this is not true im not sure on your truck seeing how its older.....alot of mech.changes have been made since then . but seeing how on a 4x4 susp. lift you incorporating another differential and alot of other parts as compared to a 2wd that has a straight shaft that will take alot less to lift in the air. ive never heard of a 4x4 lift being universal to a 2wd truck, but good luck to you
isn't the front of the frame different?
and also if your wanting a 4" lift kit for a 4wd on your 2wd you would get 6" of lift if it was to work, which you could just get a 6" 2wd kit and sit how a 4" lift 4x4 would be
also there is a thread with the height of our trucks, im at like 45 3/4 w/ my 6" 4x4 lift and wxscpo is at 43" or so with his 2wd w/ a 6" lift
