AS 2.5in Leveling kit installed but i think there is a problem?
Old 04-29-2009, 11:57 PM
way2qk4u2c's Avatar
Ok so i installed the AS 2.5in leveling kit tonight. After i got it all done and took it off the jack stands well it sure seems like the front end is super stiff now. Also my drive axles seem to be angled alot and it doesnt look its suppose to be like that. I saw the pic of the write up on how to install them and looking at his axles they seem pretty good with no strain on them.
Also when i go into 4x4 mode i get a clicking like from the axle grinding?
Did i damage something or while installing it can you lower the control arm to low and cause problems on the axle?
Is there a "R' and "L" on the AS 2.5in kits or either will work for each side?
I don't want to put to much strain on my axles or suspension components. Ill try to get pics of them to help show you what i see.
Old 04-30-2009, 07:06 AM
F_ast's Avatar
you will need to have an alignment done before you can comment on ride, control stiffness and function. toe in or out and off camber will play tricks on you.
Old 04-30-2009, 10:38 AM
mdhawkin's Avatar
The spacers are universal left/right does not matter. Everything only goes back together one way, the only thing you could do wrong is not meeting torque specs. As F_ast said alighnment is key. I think you will be ok. If you think things are out of wack get us those pics.
Old 04-30-2009, 06:19 PM
way2qk4u2c's Avatar
Here are the pictures... i hope a alignment will fix this? Or does this look right lol
Old 04-30-2009, 10:25 PM
fx4tough07's Avatar
Are you sure they didnt sned you the 3" kit on accident. Did you measure the spacer by chance??
Old 05-01-2009, 12:03 AM
way2qk4u2c's Avatar
No i didn't measure the spacer???? I dont feel like going through all the trouble taking it out if they did. Ill be pissed.
Does this look bad? Is this possibly be able to be fixed by an alignment
Old 05-03-2009, 01:39 AM
DXB-F150's Avatar
Good point by fx4tough7!
By any chance have you experienced any clunking noise when your suspension is extended to the max? I have a 2.5" leveling kit with stock shocks and my upper control arm is making contact with the spring when the suspension extends fully.
Im trying to figure out how to prevent this from happening on my truck.
Old 05-03-2009, 09:34 AM
fx4tough07's Avatar
Can we get some side pics of your truck to see if the front end is higher than it should be??
Old 05-03-2009, 10:06 AM
AS doesn't make a front 3" spacer that I'm aware of.
What front shocks are those? If they are longer than stock that is your problem. Adding the spacer to longer shocks won't work.
Old 05-03-2009, 11:15 AM
fx4tough07's Avatar
AS makes a 3" spacer, i just got mine last week.
Old 05-03-2009, 12:00 PM
way2qk4u2c's Avatar
Ill get pics sometime today for ya
I just got back from the alignment place and the axles look pretty much the same as they did before.
I still dont like how they are sitting-
I measured the spacer itself- its only 1.5in? What size should they be? Can someone measure there spacer that hasnt installed theres yet?
The strut is a ford strut so it should be stock. So im not sure if its longer than the normal ones?
I get no more clunking in 4x4 mode and i dont ge tclunking going over bumps? Im just worried about the strain on the axles.
Old 05-03-2009, 02:58 PM
way2qk4u2c's Avatar
Here are the pics...everytime i look at it the more i think there is something wrong lol.
Old 05-03-2009, 03:15 PM
JWBFX4's Avatar
The AS 2" spacers measures 1 5/8 and the 2.5" measures 1 3/4
Old 05-03-2009, 03:27 PM
way2qk4u2c's Avatar
I measured the spacer while on the truck so i might not be getting a accurate measure but i sure know i dont have a 3in spacer from AS...so that rules out that idea.
The truck is leveled nicely though...
But does the axles look ok though- is this normal?
Old 05-03-2009, 04:09 PM
JWBFX4's Avatar
Well the bigger the spacers the worse the angles will look...back to your first post though...I have had no problems with mine. It seems that the ride comfort has been unchanged...no unusal noices or problems. As far as if the angle looks normal, honestly I don't know to much about the front suspension to give a good answer, here is a pic of mine with the 2" AS
[IMG][/IMG]
Quick Reply: AS 2.5in Leveling kit installed but i think there is a problem?
