Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Sign in using an external account
Register Forgot Password?
Register Photos Vin Decoder FAQ Members Search Today's Posts Mark Forums Read VendorsGarage
Suspension SPONSORED BY:
Thread Tools Search this Thread Display Modes
Old 04-23-2009, 11:20 PM
Garage is empty, add now
Vehicle: 2001 ford F-150
rcd lift kit
my buddy has an rcd suspension lift on his truck which is a 2001 f-150 regular cab short bed. i want to take the lift off his truck and put it on mine which is a 2001 f-150 extended cab long bed. the major difference between our suspension is my torsion bars are about a foot longer and it looks like it would work but i wanted to see if anyone had any undercarriage pictures of an rcd lift. it looks like the torsion bar goes from being above the transmision crossmember to underneath. i called rcd they said it should work i would just like to see a picture if i could thanks.
Old 04-24-2009, 12:15 AM
Vehicle: 2003 Ford F-150 5.4L 4x4
you sure you're not getting the impact struts and the torsion bars mixed up? The suspension lift adds the impact struts to reinforce the lift crossmember by linking it to the transmission crossmember. The torsion bars are dropped down to compensate for the addition of the two piece subframe.
I'm not trying to sound like a jerk, but you seem a little unsure of how IFS lifts work. You tear down the front end, bolt on a subframe, and the whole IFS axle, differential and all is dropped down. If you don't understand all this, I would consider paying a shop to switch the lift over for you.
Old 04-24-2009, 03:28 AM
Vehicle: 1997 Ford F150
first thing i would look at with the rcd lift is the transmission. rcd has 2 lift kits...one for the 4r70w with the 13" x 13" tranny pan and one for the bigger tranny. u have to have the correct kit for the transmission you have. i can climb under my truck fri mornin n take a pic of what it looks like with my 5" rcd lift on my 97 reg cab short box 4wd. witha 4r70w.
minimonster is correct. everything is dropped to compensate for everything up front. its a very simple kit to install. it is shocks, 5" lift spindles, subframe pieces, tranny crossmember n drop down blocks. n a new leaf in the rear. plus some odds n ends but those are the basics of the kit. i may be forgetting some since its 230 am n after bar time but yea you gte the idea.
i personally love my rcd. its sit perfect rides good and was built well.
'97 Ford F-150 Flareside
Regular Cab 4WD 4.6L----5" RCD Lift---35" Hercules Trail Digger M/Ts---17" Centerline Wolfers
K&N, Edge Evo Supertuner w/Attitude monitor, Underdrive Pulleys, 75mm Throttle body, Throttle body spacer, Full insane JL Audio speaker setup, Pioneer AVH-P5900 Flip up DVD/CD Player, PS2 Slim, 20% Tint, Leather DMC seats, Woodgrain dash inserts
http://www.f150online.com/galleries/...cfm?gnum=10595
Old 04-24-2009, 11:25 AM
Vehicle: 2001 ford f150
I'm under the impression all of the torsion bars are the same length except for the Supercrews which are shorter.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
Old 04-24-2009, 02:41 PM
Vehicle: 2002 Ford F150 4x4
Regardless of how long the torsion bars are, it should still work. And about the trannies, I'm not really sure what the difference is as far as how the lift is constructed. If you have the same transmission, you'll be fine. Otherwise, it may not work at all.
Old 04-26-2009, 09:13 PM
yeah i'm sure what the torsion bar is and they are definantly different lengths my truck has the 4r70w and so does his so i guess it should work i just couldnt find a picture of it from the bottom anywhere on the internet it doesn't seem like a lot of people have that lift
Old 04-27-2009, 10:47 AM
personally, I am under the impression that you are still confusing the torsion bars w/ the impact struts. All F-150's came w/ the same length torsion bars, +/-1'' or so, except the F-250 LD/7700 series and a few 97-98 5.4 equipped F-150's that came with the longer ones, about 5'' longer. these trucks required the longer bars due to the having the longer E4OD/4R100 transmission, and the torsion bar crossmember must be located further back to clear the bigger transmission.
take a picture of your buddy's truck for us to see.
the only reason for there being two different kits is the addition of impact struts. the impact strut goes from the rear lift crossmember to the transmission crossmember as an additional reinforcement. since the transmission crossmember is mounted further back on the E4OD/4R100, longer impact struts are needed to reach the transmission crossmember.
Old 04-28-2009, 12:56 AM
finaly looked at his truck
i finaly got to go up and look at his truck for some reason when i helped him lift it i was convinced that his torsion bars were shorter and when i talked to him on the phone he was saying that they were shorter than mine too but i finally just went up and looked and they are exactly the same everything is the same so this weekend we will be switching the lifts. i feel stupid now but i could picture them being shorter on his truck and we were sure they were but we were wrong. maybe it just seemed that way because his truck is so much different than mine being as it is a regular cab short bed step side and mine is a extended cab long bed. oops
Old 05-02-2009, 03:39 AM
Quote:
And so the only reason for the $250 price increase is that they have to use an extra 10" of tubing? That seems pretty ridiculous, especially when the compression struts aren't even absolutely necessary.
Old 05-02-2009, 10:09 AM
actually, its more like another 5'', not 10'', lol.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
Emails & Contact Details
Search Engine Friendly URLs by vBSEO 3.5.2
