9.75 diff questions
Old 04-19-2009, 10:12 AM
wreedKR's Avatar
9.75 diff questions
Guys I am going to help a buddy change his rear end fluid. couple questions:
Do you apply RTV to the diff itself or the diff cover?
What is the torque specs on the diff cover bolts?
How much and what type of fluid will it hold?
Old 04-20-2009, 08:01 PM
borkowski4u's Avatar
rtv to the diff cover
torque specs 80 foot pounds
3 quarts pls 2 fiction modifiers, 75w-140
Old 04-21-2009, 03:50 PM
wreedKR's Avatar
hey thanks dude!
Old 04-21-2009, 07:51 PM
noblem's Avatar
Isn't the friction modifier only needed if you have the LS?
Old 04-21-2009, 09:18 PM
RayD's Avatar
I always RTV the cover, but that's up to you. 80 ft/lbs sounds like a lot for diff cover bolts, I was thinking it was somewhere around 30. You need 3 qts 75w140 and 1 4oz bottle of friction modifier if it's a limited slip.
Old 05-02-2009, 10:32 AM
wreedKR's Avatar
UPDATE UPDATE
CORRECT SPECS
33 ft lbs. for diff cover bolts
5.5 pints of fluid 75w-140.
Straight from 07 Factory service manual.
Old 05-02-2009, 05:20 PM
Roadie's Avatar
Make darn sure there is no oil draining out on the sealing surface. If there is any oil there you will have a leak afterwards. Someone posted that Autozone sells a gasket. If so, I recommend using a gasket.
Quick Reply: 9.75 diff questions
