Help!!! I put a lift on and know the wheels??
Old 04-16-2009, 03:02 PM
texasarmystud's Avatar
Exclamation Help!!! I put a lift on and know the wheels??
I just installed a 6inch Pro Comp suspension lift and know when i am driving down the road when i go to brake the tires make a whopping noise. especially when i am really slowing down and i press on the brake outside the truck you hear whoop then a pause then whoop then a pause then whoop. Help me if you know what the problem is!!
Old 04-17-2009, 12:16 AM
shifty219's Avatar
if its your tires making the noise for shure, then its sounds like your toed in to much and need an alignment
Old 04-17-2009, 12:37 AM
ATOM's Avatar
are you caliper bolts/mounting brackets tight on the knuckles?
Quick Reply: Help!!! I put a lift on and know the wheels??
