Lookin for good replacement shocks
The Bilstein 5100 series are good for your truck from stock to 2 inches of lift front and rear. This should suit your leveling kit ok.
Rancho has the RS5000. If you want to do away with existing leveling kit when you install the new shocks you could put in rachos coil over leveling kit called the quick lift.
I believe procomp has a couple of well suited shocks for you ride as well.
