04-14-2009, 11:11 AM
Garage is empty, add now
Vehicle: 2005 ford f-150 4x4
new dirtlogic coilovers
when i put them in how far do i have to crank them down to be level like i am now ,i have a 6 inch procomp stage 1, and do i have to unhook my balljoint to put them in or will they fit right in?
 2005 f-150 larait 4x4,K&N intake, edge evolution,magnaflow duals,procomp stage 1,dirtlogic 2.5 coilovers, 3inch body lift,17x9' moto 951, 37x13.50x17 toyo mt's
04-14-2009, 12:03 PM
you cant just pop the old one out and slide the new one in ithout doing anything else haha.
you need to take the tire off, unbolt the tie rod, unbolt the upper control arm, swing the knuckle out of the way then unbolt your exisiting set up, put in the coilover and bolt it back together, make sure the misalignment spacers are in the right places.
and its trial and error on the height setting, just mess with it.
ROLLING ON 40's~~Airbags on there way!
04-14-2009, 01:00 PM
ok thanks man , and do i have to get an alighment ? or only if i crank it? bc i might crank them 2 inches
04-14-2009, 01:01 PM
I think you should start off with about an inch of threads above the spanner nut. See how that comes out and adjust from there.
I cranked and I needed an alignment.
04-14-2009, 01:59 PM
2009 Ford F-150
Vehicle: 2009 Ford F-150 FX4
yea get a alignment
I need help...
04-16-2009, 09:30 PM
Is it cheaper to go with the Pro Comp Stage 1 and Dirt Logics than the complete Fabtech kit? What would be the difference?
04-19-2009, 08:46 PM
i went to put on my coilovers and the big bottom bolt for the control arm is to big to fit in the coilover, wat do i do ? and do i need a bushin for inbetwen? bc other wise it would mover around...please help me
04-19-2009, 09:02 PM
2004 Ford F-150
Vehicle: 2004 ford f150
i had a shop do mine, but when they did they had a problem with getting the coilovers in and in the process scratch my springs and up where it says fabtech, so you might you keep playing with it till you get in there
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
