Model vs Leveling Kit
Old 04-08-2009, 11:07 AM
mdhawkin's Avatar
I have read through a lot of threads concerning what leveling kit to get with mixed results. I hear many people saying it depends on the model of your truck.
I have a 2008 Lariat 4x4 SCREW with the 5.4 I measured front vs rear and came up with exactly 3'' different. I see where everyone says the 2.5'' AS will get you 3 inches so thats what I ordered.
I have not recieved it yet, but in the mean time have read more threads where some people say 2.5 is perfect some say its too much. Can anyone with the exact model I have that has installed either a 2'' or 2.5'' AS let me know the results? If 2.5'' turns out to be too much I would like to trade it for a 2'' and only do the install once.
Thanks!
Old 04-08-2009, 11:23 AM
2006FX4's Avatar
I have a 2006 Scab and I used a 2 1/2" AS. The front was about 3/4" higher than the back. Sometimes I noticed, sometimes I didnt. I did end up putting a 3" block in the back, so the problem is now gone.
Originally I was running the Rancho Quick lifts, I think I had them set to just around 2" maybe 2 1/8"or something. The truck did sit level with those, but one went bad.
I have read that the 2004-2005 had an extra leaf, and thats why the 2 1/2" levels them out. But it is different for every truck I think.
Old 04-08-2009, 11:29 AM
mdhawkin's Avatar
2006FX4 Thanks for your quick response, by any chance do you know the measurement difference of front vs rear when it was stock (before the ranchos)? I am hoping that it is less than the three inch differnence I currently have.
Old 04-08-2009, 11:33 AM
2006FX4's Avatar
Ohhh no. I did that week after I got the truck. I have no idea anymore. Sorry
Old 04-08-2009, 11:35 AM
2006FX4's Avatar
I think the 2" would have leveled the truck out nicely. Maybe a little bit higher in back if any. I got caught up in the "more" syndrome though.
Old 04-08-2009, 11:40 AM
mdhawkin's Avatar
I know the "more" syndrome you mentioned. I will continue to see what people say, maybe I can hear from somone with my exact year and model that I have and what thier results were. In the end if I am still unsure I will just install the 2.5'' that I ordered. If its too high I will add a leaf. Plan on putting 35'' on it anyway.
Old 04-08-2009, 12:41 PM
nickleej's Avatar
I asked a similar question a while back and decided to go with a ReadyLift 2" leveling kit for my 2007 Screw FX4. Im going to install it this weekend so ill post up some pics. From what others said, the factory suspension will hold up better with the 2" as well.
Hope this helps!
Old 04-08-2009, 12:43 PM
Jaderbutt's Avatar
If you plan for 35" tires in the future, go with the 2.5 kit up front and order yourself a 1.5" add a leaf and install it at the same time you do your leveling kit.
Old 04-08-2009, 12:46 PM
nickleej's Avatar
Jaderbutt,
Your post says to get the 2.5" kit, but your pic says 2"...which one did you put on?
Old 04-08-2009, 12:52 PM
Jaderbutt's Avatar
I went with the 2" but if I had to do it again I would put on the 2.5".
Old 04-08-2009, 01:37 PM
Fifty150's Avatar
Get adjustable shocks. Then you can dial in the ride height and ride firmness.
Old 04-08-2009, 02:36 PM
mdhawkin's Avatar
Thanks everyone for your input thus far. Since the 2.5" AS has already been ordered and shipped I think I will put them on once they get here verses sending them back. If they privide no more than 3 inches of lift I will be OK. If it goes more then that I will add a leaf in the rear.
Old 04-09-2009, 08:53 AM
mdhawkin's Avatar
After reading what you guys had to say the idea poped into my head, why dont I just lift the front of my truck with a floor jack to get a rough idea of what it would look like after installing the 2.5 AS leveling kit.
From what I have read the 2.5 will provide around 3'' of lift, so I took a measurement at the stock stance placed floor jack under the front center of my truck and lifted until I was three inches higher on the same measurement.
It did indeed sit a little higher in the front than the rear, but when I stepped back to look at it, I liked it. I am going to stick with the 2.5" AS if anyone is interested I will post pics, let me know.....
Old 04-10-2009, 12:43 PM
miseroth's Avatar
Pics would be great...thanks!
Old 04-12-2009, 02:18 PM
mdhawkin's Avatar
After 2.5 AS kit installed. Finished it up last night. The 2.5 made it sit a touch high in the front but not enough to bother me. If it ever does, I will just add a leaf. Let me know what you guys think!!
Quick Reply: Model vs Leveling Kit
