Anyone done AAL + 3" blocks?
Hello all,
After putting a 2.5 level on the front of my supercrew, the *** was sagging pretty good. I just put on an autospring AAL, but it still sits a little low in the back, not bad, but I can notice it. I ordered a 3" block to replace the stock one, but is this gonna be overkill? My stock tires are already looking pretty small under the truck, and next step is some 305/55/20. Thanks in advance!
yea i had that setup for about 6 months. I have a 99 so my torsion bars were maxed out as well. I planned on running 305s but now I drive 75 miles a day so kept the stock size and took the block out. So now im just on the leafs.
If I were to do it again I just would have bought a 4" block and been done. But you should be fine.
i mean if you want that look... go for it...
basically this... bear with me...
Stock: front 0 lift, Rear 2" stock blocks= rear sits 2" higher in rear ( stock)
Leveling kit: front 2.5", Rear 2" stock blocks= rear sags 1/2-1"
Leveling kit with AAL: front 2.5", Rear 1.5" AAL= rear sits slightly higher 1/2 -1"
Leveling kit with AAL & Block: front 2.5", Rear 1.5" AAL & 3"block= rear sits 2-3" higher.
hope this helps.... ive never seen it done btw... i think its gonna really make the truck nose dive.. worse than stock..
I can confirm that. I put a 2" AS on my 08 FX4 Scab and my front end nose sits 1/2" higher according to the tape. Supposedly the 2" was suppose to be the other way around. It might settle but I have some 3" blocks ordered just in case.
