2WD with fabtech 6 inch and 2.5 AS
i'm about to upgrade to the 6 inch lift. i'm going to run my 33's with just the 6 inches for a while, then when i'm ready i'm going to put the AS back on with new tires.
what's the biggest tire i can run with this setup? i'm hoping it's bigger than a 35
i have a 2WD '08 scab.
sorry for the noob question guys, just trying to figure it out.
If you run the Fabtech, AS and an AAL or bigger rear block you may be able to get away w/ 37's. I know you can do it w/ a 4wd but I'm not too sure about the 2wd. I'd say your best bet would be to do the 6" and take some measurements and compare them to what a 4wd w/ a 6" has. You can do a search and find the measurements of others pretty easily. If you're close up front then you should be good for 37's by installing the AS. W/ 37's you'll want to do a gear swap too. I know a guy locally that did mine for $500 labor each axle. What size AS do you have anyways?
So you have your DL's cranked and a 2.5" AS on top of them?!? Aren't your ball joints at their limit? Do you have any downward travel left? I haven't looked at any 2wd front ends recently to compare them to my 4wd so I don't really know.
yeah look at my angles.. they aren't bad at all. its like a 4wd with a leveling kit on it, i have pics in my gallery of them
thanks for the info guys!!
i definately wont crank the coilovers and add a leveling kit, it may be possible, but i don't want to run the chance of wearing out my ball joints
it's 2.5 inches, btw.
i'm hoping to fit 36's or 37's.
haha i have the lift bug now went up 2.5 inches and now i wana go higher and higher.
You have less to "lose" with cranking a 2wd because there's no cv shafts to worry about but the ball joints(upper/lowwer) are still a limiting factor.
What does your UCA look like right now w/ the 2.5" spacer on it? You might consider getting the coilovers w/ your Fabtech so that you can crank them to exactly what you need to squeeze in the 37's you want. If that's out of your budget and the 2.5" AS isn't giving you horrible angles, you might get yourself a 3" AS. I think I've read before that the 2wd coilsprings are shorter than the 4wd's. I can't really see them changing the whole front knuckle, UCA and LCA but I could definitely be wrong.
I know what your talking about w/ the lift bug. 2 Months after I got my truck I put a 2" leveler on it and some 35's and I tought that would be enough to quench my appetite. Here I am no 6 months after that with 10" of lift and 38's and after a week w/ that set up I already want bigger! Don't really know what I'm gonna do about it this time though.
I just looked at your gallery pics and your angles don't look bad at all. The problem is that your coilovers are only down a couple threads. That's not really cranked in my book. At most you have an additional 1/2" of lift from the coilovers but likely nothing at all how it's sitting in those pictures. What's the point of having the 2.5" spacer on top when you have another 3" of adjustment allowable on your coilovers? Get us a good level picture, horizontal to the ground, right above the tire so we can see the true angles and how much the DL's are really spun down.
Yeah that's what I was going to do with my Kings and 2" spacer but King said not to do it. I figured the same thing you did about the ride. My Kings cranked the way they are right now though give me a great ride. We'll see what happens when I finish cranking them to get another inch or so.....
Any chance you could post up that pic I was talking about to satisfy everyone's(my) curiosity?
