Adding body lift over 6inch susp...
the PA 3'' body lift contains an extension for the steering shaft to compensate for the lift. if you have manual shift 4WD, the shift lever will need to be pulled, cut, and have a 3'' segment welded in for it to look stock. it is not absolutely necessary to extend the 4WD shift lever, you'll actually have more room without extending the lever, and 4WD will still engage just fine.
