Need Some help
Need Some help
I have a 04 f150 ext cab 4x4 has 103k on it. I'm wanting to put a 2.5" leveling kit and an add a leaf. The question i have is am i going to need new shocks for the front? i see kits being sold with and without shocks. I plan on leaving the stock 18" rims on what size tire will fit and look good? and last where is a good place online that i can get the leveling kit and the add a leaf?
so would i still need an add-a-leaf in the back you think? what size tires would i be able to fit under it? Have a good website to buy from?
A 2 inch lift should make your truck sit level. If you want the rear higher you could install a taller lift block or an AAL. As for tire sizes you can fit up to a 35x12.50 tire using the oem wheels. THis is a very tight fit and they will rub the control arms slightly at full steering lock.
