Torsion crank w/ 4" rear block??
i want my truck to be about 2" taller than it is right now so it will clear 33's better, but i want a little of the rake it has right now. my plan is to crank the torsion bars up, not all the way, but most of the way, then getting a block to lift the back up 2", so it will pretty much look like it does now, only 2" taller. has anyone used a 4" block with a torsion adjustment??? anyone have pics? i dont want the tires to look crammed in there. i am either going to get 285/70/17's or get 18" wheels with 33's(love the smaller sidewall look with offroad tires)
its an 02 fx4. ext cab.
thanks
thanks
crank the torsion bars. 2" is the max youll get out of it and that may not be the best thing.
why dont you just crank the torsion bars to level it out, or slightly under, and throw some 33s under there? i was running that setup for a while and loved the look of it. only money you need to invest is the tires and/or wheels.
33s fill the stock wells nicely without looking crammed.
Did you have any trouble getting it aligned? Im planning on doing it to mine soon even though its "suggested" not to. I was gonna go as tall as i could with tortions, put blocks in the rear to level it and run 33s.
I personally don't know if the block or AAl is best, but I chose the AAL because my factory leafs are shot and the truck squatted with light loads so I knew the AAL would beef it up and it did. The AAL cost around $55 (had to spend an unexpected $50 during the install for longer u-bolts because I didn't remove the bottom leaf) and I installed it pretty quick.
Looks good I think the rear of mine sits a little higher than my front but either way sounds like a winner. what kind of exhaust is on your truck? got a video?
my exhaust setup is. rear cats deleted- then the factory piping to the rear axle- muffler deleted-ypipe installed and 18"x3.5" ss tips. and i dont have a video, but i want to make one, i just dont have a video camera.
