6 in fabtech with dirt logic trouble
Ok so last weekend i bought a used fabtech lift with the dirtlogic's, removed it from the one truck installed it on mine put hers back to stock. great ok luckily it all fit...
first issue was the rear ebrake cable was rubbing on the tire, no problem put in a 3/8 wheel spacer took care of that! second problem the sway bar is rubbing on the strut bar things that go from the dropped brackets to the rear cross member still have to fix that i guess we mounted the strut bars to high? i really don't know but it makes an awesome screech when i hit big dips! and my last thing..... the spring on the dirt logic rubs on the shock body..? anyone have this problem and how they heec would i go about fixing that?
i really cant see anything messed up about it but the spring is def not straight it kinda bows and at the bow it touches the shock. my camera is charging ill get a picture in a few min
thanks, JOSH
thanks, JOSH
