Do I Need A Steering Stabilizer???
Don't know if anyone else has had this issue but I'm stumped. My 2000 has a 3" body lift with 35's. I periodically get a vibration back through the steering wheel. Made sure wheels were balanced, didn't help. Moved rear tires to front, didn't help. Ball joints are about 20k old everything else feels tight. I saw by chance when I was ordering new Bilsteins that Rancho offered a steering stabilizer that was recommended if over size tires are installed. Any input is appreciated.
You should check your Idler Arm. I got a 2001 F-150 4x4 with 35's. I was getting bad "death wobble". I found the Idler Arm was severly worn. If you put a stabilizer on with out checking everything. You could just be covering up a problem that could be costly.
