Not so new question on AS levels
Ok, don't curse the new guy, tried the search engine...bottom line, the front is exactly 2" lower and will be adding the 2" AS kit. Will this kit level it out or will the rear end require a 1" block or AAL to truly level the truck out due to the installation process? Or is it just better to do the rear end due to loading / weight in the back bed or towing?
Thanks in advance.
Thanks in advance.
