which rsx schocks do i need to replace my stock ones on my 02 super crew fx4
i see all different type models ,just want to make sure i order the correct ones .
Thanks guys
If you are referring to which Rancho shock is the same as your OEM Rancho's, there is not one (unless you buy them from Ford). The OEM Rancho's are valved to Ford's specs and are different than the RS5000 or RSX. Both of those would be a vast improvement over the OEM Rancho's.
