What is this part called?
Old 03-17-2009, 08:42 PM
chossy's Avatar
These photos are of behind the front passenger side wheel of my 2000 F150 4x4. I found a bolt head in my driveway and after doing some looking I figured out where it came from. I'm not sure what this part does and what it would be called. It seems like it should be a pretty straight forward repair. Any information would be greatly appreciated.
Old 03-17-2009, 09:01 PM
4.2trimble's Avatar
its a sway bar end link or stabalizer end link.
they are simple to replace.
Old 03-17-2009, 09:05 PM
trk35's Avatar
It is an easy repair if the old bolt is out of there. Sometimes they can be rusted up a little and take some "persuasion" to get them out. Usually, all you need is a hammer, and to install a 9/16 wrench and socket.
Hope this helps.
Old 03-17-2009, 09:09 PM
4.2trimble's Avatar
Hope this helps.
haha ive replaced those stupid things on my last 3 fords. and twice on he F150.
Do both at the same time. (or you will just be replacing the other one very soon)
and i didnt bother unbolting i just cut the stupid things off.
Old 03-18-2009, 02:05 PM
agreed sway bar end link
Old 03-18-2009, 03:09 PM
Hespen537's Avatar
Changed that thing on dads expedition. It started out loose and then it broke off after I tightened it. PITA to get the bolt out of that sleeve but I managed.
Old 03-18-2009, 05:00 PM
dirt_bound's Avatar
i beleive its a do-hickey or a thinga-majiger now its not gonna be cheap to fix either, your gonna need some blinker fluid and a flux capacitor just to get it outta there...now putting it back in your gonna need a sledge hammer and a blow torch you need to be careful tho you may break it that would be expensive ...if that doent work....go to a mechanic hahah jkjk i just had to say it...im tryin to be funny but ya i agree with trim and patman
Old 03-19-2009, 06:26 PM
chossy's Avatar
Thanks guys.
Quick Reply: What is this part called?
