04 2wd Screw NBS, 5" Block, Brake/Driveshaft Problems?
I have a 2004 XLT Screw 2wd with the 6" Fabtech basic lift. I'm currently using the 2" rear block that was included in the kit. I've been wanting to throw the 5" block in the rear, but had some questions about it:
1) I've heard that the parking brake cable won't reach without a special bracket. Is this true? If so, where could I source one?
2) Would there be any issues with the driveshaft by using a 5" block? If so, how would I remedy it?
Thanks!
Sean
Thanks!
Sean
Thanks!
Sean
Thanks!
Sean
Is there a way to tell if I'll need a spacer before I go to put the block in?
It doesn't seem like it is a huge deal, I would just fab up a little bracket like Davespeed did and call it done.
f22a -I`ve been running my same shock`s when blocks were replaced plus I have an additional 1,5 lift shackle to. I`ve had zero issue It`s been 2yr`s and over 50,000 miles. (Shackles were put on summer 08)
