6" pro comp lift es shocks
first - when this kit says "extended periods of high speeds in 4 wheel high.......you will need a new drive shaft from transfer case" how fast....how long? Is this due to the angle after the lift is installed? second - i used a 2.5" leveling kit.....will this effect the installation of the lift?
are you stacking the 2 1/2" spacer ontop of the pro comp spacer to get 8 1/2" of lift? stacking spacers is not good. get adjustable bilsteins or coilovers
as for driveshafts, 6" you don't need to extend the driveshafts usually. 8" or more of lift usually you need an extended drive shafts.
here in texas we dont need to drive in 4wd for long periods of times at high speeds so i cant be to much more help with high speeds. maybe someone from up north can be of more help with this.
long enough? maybe. i can probly get you a set that will be long enough. im going over to fx4 for life's house tomorrow to install him his old Pro comp block under his new block to level the rear. let me know if your interested and ill talk to him on price for you. he just bought them like 4 weeks ago and is getting new ubolts tomorrow so their basically new
The pro Comp lifts come with the 4 inch blocks and the u-bolts to make it all work. also if you have the money go with the stage 2 kit, the coil overs look better, perform better and give you the easy option to go higher later on down the road. i would say you do not need to extend your drive shafts, also i have no clue why you would need to use 4wd in high speeds for long periods of time. anyways i hope this helps and good luck.
