torsion bar crank questions
well unfortunatly the 6 inch fabtech i was about to order isn't going to happen for a few reasons, mostly because i can't afford to do it right (gears(a must cause i tow a lot), tires, wheels, etc) so i settled for a torsion bar crank.
after competeing the torsion bar crank this afternoon, i have a question. i counted the threads exposed on the bottom of the adjusting bolts before and after starting
Before: L= 7 R=10
After: L=2 R=4
this just doesn't seem right to me i would have thought that they would have been equal in ratio (ie: after L=2 R=5). Both sides were cranked exactly the same, 6 full rotations. The height gains measure up to withing a little less than quarter inch, so i just figured it was measuring errors. Any suggestions, is this common??? truck is now sitting level, i gained 2" over stock. It will go for alignment tomorrow as i assume it will be pretty far off.
truck is 00 f150
thanks for all help!!!
Before: L= 7 R=10
After: L=2 R=4
truck is 00 f150
You are putting waaay too much thought into this than required. Here's what I've done on three truck and zero issues what so ever...crank both sides up full to the stops (til you bottom out the bolt) Look at the truck, take measurements or what ever to determine if one side his higher than the other. Take the high side and lower it just enough to make it level side-to-side. You're done. Do not worry about how many threads are showing vs one side or the other.
