Rancho 4inch... Shocks?
i need to get Front and Rear shock for my 2004 f150 (newer body stylewith the Rancho 4inch lift. i do not want the adjustable ones with a little dial i have to change i want some that wont be expensive and will get the job done just do not know how to order or what to look for because the Rancho ones i do have, have a much longer spindle in the front compared to stock because they do not use a spacer that is added on top of the whole spindle assembly....
Any help would be great thanks!!!
well your only options are the rs5000 or rs9000. they ain't exactly cheap either. if paid 293 for all 4 shipped last year and that was a smokin deal! i would guess your looking at 500+ for shocks
the front's range from 160-185 depending on where ya go
and the rears are around 85-100
not really, i read that the bilstein shocks won't work for the front, but they are 400'ish for a set too. nothing is cheap when they know you can scrape your insides because they know you need special shocks. i was gonna put fabtech coils in the front of mine soon, but that is put on hold otherwise i would sell you mine.
But there should be no need to spend the money if you don't need to or replace a perfectly good adjustable shock with one that you cannot adjust AND spend the money.
ATOM-
sounds like and awsome set up cant wait to see some pictures!
Stove Top-
unfortunatly when i put the rears on (since it was easy to install all that) the shocks performed as if they were blown so i figured just turn them to position 9 and problem solved that was not the case they still were very weak and lead me to belive that there time has come to be thrown away i do not know how or why they are like that but there is not much i can do :/
Stove Top-
ATOM-
Stove Top-
Stove Top-
Good luck and post pics of your lift when you get it all figured out.
Actually the Bilstein stocks will work, but not ones for stock height your lift is over 2". Your option with Bilstein is the 5125's here - http://www.shockwarehouse.com/site/bilstein_5125.cfm.
You will have to know the expandable and collapsible lengths you'll need. (your lift manufacturer can let you know this).
Feel free to let me know if you have any questions.
