Replace stock block with 2'' lift shakle?
lift shackles are very easy to install, and arent expensive to buy. however, im not sure what sizes are available. i have 1.5" lift shackles on my truck, and i got about 1" lift in the rear from them. i use them to offset the "nose high" look that the lift gives, since i like a little bit of rake.
i think that if you take the stock block out, you will not gain those 2" back from a lift shackle, unless you can find a 3" shackle.
you wont find a 3" shackle for these trucks. the way they have them set up is the leaf swings above the shackle mount instead of underneith it. by doing this you would have to find a shorter shackle than the stock one to lift it, a longer one will lower it.
The ford rangers work the opposite way where the shackle mount is set up so the leaf will swing under it so a longer shackle wil lift it.
Or you can cut off the mount thats on the frame and weld it on the opposite way so the leaf hangs under it and then a drop shackle will then lift you up.
And would the truck ride better without the stock block or i would be wasting time and money?
dont waste your time or money.
shackle lifts really do you no good. youll see no difference in ride and the shackle will flatten your leaf spring out.
there is nothing wrong with the block in there. if you want a stiffer suspension take the block out and throw an add-a-leaf in its place.
I already have the aal and want to take it out. That's why i thought about the shackle lift to keep my little rake. But i guess a 3'' block would be better.
