Need your help guys.
Hey everyone i need your help. Just about a week or so ago my truck started to make a popping or clunking noise coming from the front end. It seems to only do it when im turining and backing up at the same time. I have no clue where the noise is coming from so i need some opinions.
Oh and my truck is a 2005 FX4 with a 6in. RCD, 35.1250.17 Toyo M/T's, 17inch eagle alloys, 4.56 Yukons, Roush Off-Road Exhaust and Volant intake.
Thanks guys!
-Mike!
Thanks guys!
-Mike!
hey, i have the same lift and tire size as you.... what have you checked so far? i would start by checking the ball joints, and then all of the bolts up front.
i have had my lift for just over a year now, and the only problems i have had is the lower control arm bolts loosening up, and also the front driveshaft bolts loosening up where it mounts to the transfer case
take a loook around to start with, and see if anything obvious presents itself.
by the way, how do you like the 4.56 gears? i still have the stcok 3.55's, and am thinking about upgrading them.
