suspension lift 4x4 vs 2wd
The reason why i say this is because it will make the long be look slightly shorter... and the tires wont seem SO far appart and small
id do your 6 inch lift, then put a body lift on it and run the 35s. i think on that body style if you only go with 33s your going to end up wanting to go bigger anyways. might as well do it right the first time
this is close to what you would have with a 6" lift on 33s
heres a pic i found of a 93 reg cab long box on 35s. its a 4wd with 7 inches of lift, roughly where you would be with 6inch suspension and body lift
