Lift/Wheel Spacer question.
I need to know if I need to take the wheel spacers out that I have in now. I am running 325/60/18 terra grapplers right now and they stick out quite a bit. But I heard when the Pro Comp lift is put on, it widens the wheelbase. Should I take the spacers out?? Thanks!
this is completely up to you. i personally wouldnt run wheel spacers. yes, some lifts do increase the front track width. however, not by too much... how big are your spacers? you could possibly run them only on the back to offset the lifts affects up front.
are you running stock wheels? i was running that same tire size with aftermarket wheels and a 2.5" leveling kit, and they rubbed the front fender pretty good.... i couldnt imagine what it would have done with spacers too.
