Front suspension overhaul
I have an '04 FX4(new body style) that is in need of an alignment. I took it to the shop today to find out that my lower ball joint on my drivers side was toast along with the ball joint on the passenger side outer tie rod end. I want to break my suspension down and replace all of the b/j's with serviceable grease joints. The truck is on the stock suspension, with a leveling kit. What parts will I need for the project. Looking to do this ASAP so that I don't wear out this free set of $1250 tires that I have! I have searched till I am cross eyed! Also, if I ordered parts that are for the '05 FX4, would that work? I have heard that you run into getting parts for the old body style if you aren't careful? Thanks!
I looked at that site...quite difficult to navigate(could be me...just tired). I will check it out tomorrow. I was thinking I would replace my upper and lower ball joints along with the tie rod ends. Is it true that I have to get the whole upper a arm just to replace the ball joint? Is it the same with the lower one?
