Eibach Pro-Truck Kit
Hi All,
I just ordered the Eibach Pro-Truck 2/3 lowering kit and their Pro-Damper Shocks as well.
Did a lot of searching and watching threads about lowering trucks and finally settled on this setup.
Don't know if I will get the Groundforce Lowering Shackles yet or not.
There is a lot great info here in these forums and I thank everyone who has posted in these, to help others.
Thanks again,
John
Thanks again,
John
Did you install it yourself or have it done?
I understand that you have cut the left front hanger bolt off or drop the gas tank to get the spring off.
I think that I will see how I like the looks and function of 2/3 before I get the other shackles.
Anticipation is difficult, but I can do it.
If I stare at it long enough I will figure it out. Then with a few libations on hand, I will delve into it. Right now I am thinking where I am going to do this operation, as my garage is kind of half full of junk. I think that I am going to need the whole garage floor for this one. Just have to keep telling myself that a human engineered this, so another human can do it too.
Just take my time and not throw too many wrenches at the walls.
I thought I read somewhere that you take a sawzall to the bolt head and then remove it and replace with a new grade 8 bolt and nut. Have not looked at the clearance around the bolt and tank area yet to see if this is possible.
If I did just cut the bolt, I would loosen the bolt up so I could get enough room for the blade to go between the head and the hanger and then pull out the remaining bolt with the nut.
Guess I will have to get under and see what is up.
If you guys said you dropped the tank and it was not too bad, I will keep that idea in my mind as well.
Thank you,
John
Thank you,
John
I can't believe it!
The parts are here already!
Got them in less than 48 hours. Wife called around 1 pm to tell me that :santa: was a couple of months late but he finally did make it with my parts.
Now I just have to wait for some good weather and possibly bribe my BIL to help me. He used to wrench on cars when he was younger like most of us did.
Yea when we did stealth's truck we put a floor jack under the gas tank with a 4x6 timber to support the weight across the tank. We loosened the straps and slid it forward and towards the center of the truck until we could get the bolt out. Actually never had to "lower" the gas tank, just kept it on the jack and moved it around as necessary.
