F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Suspension
Thread Tools Display Modes
Old 01-05-2009, 11:06 PM
Vehicle: 2004 Ford F150 4X4
Question Bilsteins 5100 vs HD Confusion...
In another post a forum member posted this:
Quote:
Bilstein 5100 Info - From Bilstein
Hey all
I emailed Bilstein about their 5100's and why some have 2 settings and some have 3. I also asked them to settle the dispute on which way the rears get mounted. Boot up or boot down.. Here is their reply..
----- Thanks for you inquiry for Bilstein shock absorbers. You have made a wise choice with your decision to use Bilstein 5100 Series to level your F150. I am sure you will be very pleased with the end result.
As for your questions. First, Bilstein produces two different shocks for this application. One of which, is proprietary through RCD Suspension. The other is Bilstein's general aftermarket offering. Both shocks are exactly the same with the exception of the snap ring grooves.
Part# BE5-C298-H1 is Bilstein's standard product. This shock has 3 grooves for 0" - 1" - 2" ride height options.
Part# BE5-C293-T0 is the RCD product. This shock has 2 grooves, 0" & 2".
As for the rear mounting orientation. The rear is designed to mount body up with the boot down.
So I look around for the 5100 with the 3 grooves # BE5-C298-H1 and several sites and end up at Summit Racing Equipment (free shipping).
They have the front 5100 but cant give me the rear PN and try to sell me the HD rear shock insisting that the Bilstein part numbers dont show the rear 5100 for my truck.
So then I email Bilstein directly and ask a few questions like, what is the difference in the 5100 and HD and can I mix them since the HD's are a few bucks less and this is the response:
Quote:
There is no problem mixing the Bilstein 5100 shocks and the HD’s. Internally, the basic design of the shocks is the same, and though there is a slight difference in the shock stiffness between the HD’s and the 5100’s, it is minor. The HD’s will be slightly more comfortable, but the 5100’s will handle slightly better, but on normal roads at normal speeds, it will be virtually impossible to tell any difference. It is far more important to get the shock that is the proper length, which in your case would be the BE5-C299-H0 shocks.
This is the link for prices of the 2 types
So here is my question to the forum.
Anyone ever mix front and rears this way?
If not, would you, why and or why not?
Wake up, Neo... The Matrix has you...
Superchips,Injen,Corsa
Old 01-06-2009, 12:14 AM
Vehicle: 2006 Ford F150
Send a message via Skype™ to brianjwilson
Okay so I'm not understand exactly what/why you are trying to do. Instead of ordering a set of the 5100's, your trying to save a few bucks and buy the HD's?
Four of the 5100's (with only the factory height and 2" setting) from topguncustomz.com is $389 shipped I think.
Technically there is probably nothing wrong with mixing the shocks but it will look funny having a shiny shock up front and a blue/yellow shock out back.
2006 F150 FX4 Super Crew - 5100's leveled 2", 35" BFG KM2's, AEM Brute Force Intake, Xcal 2 (VMP), 15% tint, ARE Z-Series, Hella Heads...
2003 VW Jetta GLI VR6 six speed, 2" drop on 18's, eibach sway bars, magnaflow catback
My Trucks
Old 01-06-2009, 03:01 AM
Originally I wanted a set of 4 with the front having the settings of 0-1" and 2".
I found the front 3 position shock but they didn't have a part number for the rear 5100.
Then after research I found out the HD is a tad softer than the 5100 and I considered putting it on the rear instead of the firmer 5100 but I didn't know if there are any unintended or unplanned consequences to different types of shocks in the front and rear.
A pair of 5100's for the front are $50 more than the HD's and I assumed the rears were also more but they are the same price for rear HD or 5100's shocks.
I have seen 3 different sets of front shock part numbers and 2 different PN for the rear 5100.
Since I posted someone showed me some photos of their shock with a good number so I will end up going with a set of (4) 5100's
Old 01-06-2009, 09:16 PM
Vehicle: 2004 ford f-150
Old Dog, I have the HD Bilstein's front and rear on my truck. I wanted a little heavier shock's in the rear is because I pull trailers every once in awhile. Also my leveling kit is still in good shape so I put the HD's in the front also. Also I read that the 5100 series are a longer travel medium duty shock designed for leveling out or using with a full suspension lift. Also the HD's I have are mounted with the boot up, toward's the truck bed. I find they ride firm but not rough and handle the side to side roll a lot better than the stocker's. I've put about 3k miles on them and so far well satisfied with them. Either way both are great shock's.
2004 Lariat 4x4 Screw, 2 1/2" Daystar leveling kit, K&N drop in, American Racing "Crater"" 17x9 wheels with 295x70x17 Toyo MT's, SI/DO Magnaflow exhaust with 3 1/2" SS tips, PE Jackrabbit Cover, Edge Evo Programmer, , Bilstein shock's.
Old 01-06-2009, 11:07 PM
Quote:
Thanks for the response!
Did you buy your truck new? I remember when my truck was new and unloaded the rear was bouncy and I wished for a softer shock out back. The Bilstein tech said the 5100 were a bit harsher on an empty truck.
I think I have front and rear torsion bars because I corner hard and never have much body lean.
At least once a year I load up heavy and travel cross country and with the stock rake it looks like my truck is lowered even front to back. Im afraid if I set the front 5100 on 2" when im loaded I will need the firestone airbag leveling kit so I wanted the ability to adjust the front down if I need but under normal conditions I want a bit less rake.
What is the difference in which way the rear shock is installed?
Thanks again PawPaw!
Old 01-06-2009, 11:16 PM
Yes Old Dog I bought it new at the end of Jan. '04, 1 more note and She's mine! Look in my gallery and see how bad the rake was when stock. I had her leveled out about 3 1/2 yrs. ago and have been running larger tires and wheels for a little over 3 yrs. Truck has close to 60k miles and just had the shock's changed out at about 56k miles. Rides a little stiffer than with the stock shock's but handles a lot better.
Old 01-06-2009, 11:42 PM
Here are the 5100's I ordered. These only have stock height and +2"
http://www.topguncustomz.com/Store/G...view=193574766
Here is my truck with them installed with 35's.
Bilstein 5100's, 35's and window tint!
The 5100's ride GREAT, I love them. They are even better now with the heavier 35's. I would highly suggest them.
You wouldn't want to be adjust the front down anyway, since it requires removing the coilover, compressing the coil, re-setting the spring seat, re-installing and aligning again.
Mine still has some rake, and I may go with a 1" add-a-leaf. If you tow/haul much you will love the airbags, otherwise I would use a small block or add-a-leaf and not worry about it much.
My Trucks
Old 01-07-2009, 12:53 AM
Im going to probably go with +2 and the firestone helper airbags I guess.
Thanks for the input!
Old 01-19-2009, 09:04 PM
Vehicle: 2007 Ford F150
What email address did you use to contact Bilstein?
2007 Ford F-150 King Ranch 4x4, 2" A/S, JL Audio TR570-CXi, Weathertechs, Passport 9500i, NFab LB 4x PIAA 520s, Bilstein 5100s in rear
2009 Lincoln MKX
2006 GMC Sierra 2500HD 2WD LBZ, Banks Six-Gun, Magnaflow 4", Banks RAM-AIR, T-Bars cranked, Weathertechs
2007 Honda CR-V EL-X 4WD
2004 Chevy 3500 Duramax Dually 4x4
1997 Chevy 1500 Suburban 2WD
Old 01-30-2009, 11:28 PM
Quote:
kfoote@turnermotorsport.com
Here are some photos of the 3 ring front Bilsteins 5100 struts I wanted.
1st ring is stock setting for a 4X4
2nd ring is 1" above stock 4X4
3rd ring is 2" above stock 4X4
Snap ring is in 1" position.
Old 05-23-2009, 02:02 PM
5100"s
I have a 2006 xlt with 6-1/2" bed, crew cab. I love this truck. 45,000mi. now. I do hate the factory rake though. I am not really very mechanically skilled. I was just wondering if there are any problems with using these shocks to eliminate the rake. I was considering using them only on the front. Everybody talks about the improved ride. Improved how, because I actually don't have any complaints about the ride now. I know I will obviously need an allignment if I put these on the front, but does anything else suffer from the installation of them such as ball joints or any steering components. I would appreciate any imput you could give me. Also your truck looks awesome.
Thank You
Old 05-23-2009, 02:51 PM
Vehicle: 2006 Ford F-150
Quote:
Thank You
The 5100's set to 2 inch lift are a great way to correct the rake. They are better than a leveling kit spacer because they give you more suspension travel. They should not have any adverse affects on your ball joints, cv joints etc. Someone mentioned where to buy them earlier in this thread. If you install them your self I would recommend removing the old ones and leaving the coil on them (DON'T REMOVE CENTER BOLT ON TOP) and taking them to a shop and have them switch the shock out of the coil. You need a heavy duty spring compressor so it is probably easier and safer to take to a shop. Those can be dangerous. I've heard great things about them and am planning on putting them on my 2006 XLT 4X4 Supercab. Do a search for Bilstein 5100 on this site and you will find a lot of info and members that run them.
Old 05-26-2009, 04:42 AM
Vehicle: 2005 FX4
As Im overseas, there is no shop that I can walk into and pick up a set of the 5100's and have a look at how they work, so can someone explain to me how they level the truck?? I understand the grooves allow the spring seat to be adjusted, so does that mean that the rod that slides inside the shock extends to accommodate the higher spring seat position, hence pushing the truck up and leveling it?
I was talking to a shop here that sells Rancho's and he got me all confused on how their shocks work saying that they would compress my spring and make for a firmer ride. That is not what Im looking for so I need to have it confirmed to me that the 5100's do not work the same way.
Furthermore, as my levelling kit is not offset I am experiencing that the upper control arm hits the spring on occasion. Will the 5100's eliminate this problem entirely?? If so, how?
And finally, I find the back end to be a bit bouncy. I'd like something that will smooth that out. As the only load i carry is a dirt bike and some camping gear, could i get away with a set-up like this?
http://cgi.ebay.com/ebaymotors/2-Bil...Q5fAccessories
Thanks!
Old 05-26-2009, 05:30 PM
Site Sponsor
The 5100s are a very popular shock for F150's. We have them for 10% off and free shipping.
Online distributors for Airlift, Bilstein, KYB, Edelbrock, Monroe, and Rancho.
Visit Shockwarehouse.com and use PromoCode F150 to receive your 5% discount upon checkout.
FREE SHIPPING for orders over $95!
Follow us on Facebook!
BrakePadWarehouse.com - PromoCodes and FREE SHIPPING rules apply here too!
AutoLoanDaily.com - auto Loans, bad credit auto loans and auto financing news.
Online Since 1996
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
