01-02-2009, 03:43 PM
Garage is empty, add now
Vehicle: 2006 Ford f-150
negative camber??
i dont know if thats right or what but i took it to a body shop today and i overheard them say that..but they said i need a new upper control arm and a new knuckle cause they go together?? and i took it to another place and they said that their 2 different parts, not toghher..??and i wouldnt need to replace it..
my question is..with "negative camber" does the knuckle or the upper control arm need to be replaced..they priced the knuckle at 200.00 and the upper control arm at 80.00..plus labor..so im trying to save some cash if the knuckle isnt that important..thanks..
01-02-2009, 04:56 PM
i dont understand why you would need new control arms and a knuckle? camber bolts can correct that. what is done to the front of ur truck? leveled?
01-02-2009, 05:07 PM
ohhh sorry forgot to explain..my wife got hit awhile back and they put the new wheel on and aligned it like 4 times and its still like that..and i bought the truck as is..and it has like those spacers in it with a leveling kit which i do not know what size..
01-02-2009, 06:08 PM
um, take a picture of the upper control arm, i couldnt imagine you could drive the truck if the knuckle and upper control arm were bad.
they are two different parts and do not need to be purchased together.
if you have negative camber it can be corected my cambolts.
ROLLING ON 40's~~Airbags on there way!
01-02-2009, 09:50 PM
ill take pics in the morning, and ive been driving like that for like weeks..it just rubs passed 40..but i dont past 65..when im on the highway..cause its kinda scary haha..
01-03-2009, 10:57 AM
hahaha thanks for the clarification, i was shaking my head on that one, i probably wouldnt drive that thing at all if it had bad suspension components. pics will def clarify and some of the guys on here really know there suspension stuff so i am sure one of them will point you in the right direction.
01-17-2009, 09:21 PM
01-17-2009, 09:35 PM
3 inch body lift im guessing..
leveling kit?? dont know what size..2.0? who knows if you know thanks aloooot.. just want to know if its a 2.0 or less cause theres no point of getting a 2.5 if it still isnt level with whatever size that is..also have longer ubolts, meaning what? sorry for all the dumbass questions but ive been trying to get this right for almost 4 months..no shops know nada..
and this (driver side..wrecked)arm is closer by like half an inch to the tire than the other side
01-17-2009, 11:14 PM
Looks like you have one of those cheap department store coilspring spacers. Actually it looks like you have two. They are the things wedged in between the coils of your spring in the pics. I can't tell if you have a proper coilspring spacer at the top, but it appears you may.
2005 Expy, 305/45-22 Falkens on 22x9.5 Eagle 026s.
2011 Jeep Wrangler Unlimited, 2" lift, 33" BFG AT KO's on 17x9 Eagle 197s.
2012 Ram 2500 crewcab diesel. 5" RCX lift, 355/60-20 Nitto Terra Grapplers on 20x9 KMC XD Spys.
01-18-2009, 09:17 PM
should i remove those and add maybe bilsteins? to get the same amount of height?
01-18-2009, 09:20 PM
Yes, you need to remove them before they destroy your coils if they havn't already.
01-19-2009, 01:21 PM
ok so i remove those..and if they already did get ruined which i might think they did, cause it rides rough when i hit bumps..dont know if that has anything to do with it..what kinda of coils do i get? and what kind of price range do these things cost? and i can add the bilsteins with the new coils, correct?
01-19-2009, 05:52 PM
soo i think i found out the problem..i just came back from the body shop and they showed me a broken "STEERING RACK AND PINION" and they said my front lower balljoints are shot on both sides..they also said when my wife got hit in the accident that the lower control arm slide inward causing the "negative camber" but they said that the negative camber is going to stay like that forever..thats where it gets me thinking..they said with all the new ball joints and new rack and pinion, its going to stay the same but just with new parts? Anways they also said the tire was negative .50 or half an inch.. and cant be fixed..so who knows.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
